Piston/Rod setup
Old Mar 15, 2005 | 01:52 PM
debestuss's Avatar
debestuss
Originally Posted by rusty70f100
On the 10.1:1 compression, they say that, but I dont think they figure in the head gasket. The L2291's are supposed to have 10:1 compression. They dont. When you put a Fel-pro .041" thick head gasket on there, it's more like 9.5:1. Those you found would probably be fine. What are they, Clevite?
Yeah, Clevite. Also, I looked under 1969 Ford Galaxie 500 and found this one, CEP 2241713, which has an advertised 10:1 for $10 less. Keeping in mind that I seriously doubt I'll ever have the factors that would give me 10:1 with that piston, this might be the one. Is cast aluminum a problem?
Old Mar 15, 2005 | 02:20 PM
rusty70f100's Avatar
rusty70f100
Cast pistons are not a problem at all unless:
1. You EVER plan to run nitrous.
2. You EVER plan to run forced induction.
3. You EVER let it ping.
Pinging is not good for pistons, cast in particular. If you hear any, be sure to get it taken care of right away. Forged is much more forgiving in this area.
Other than that, they work fine.
Old Mar 15, 2005 | 03:00 PM
debestuss's Avatar
debestuss
I will never run nitrous, I will never run forced induction, and I hope it will never ping.
Fellenz
23
Dec 8, 2014 04:51 PM
1975FordF250
Apr 5, 2014 09:40 AM
Kevin T
3.8 & 4.2L V6
Aug 1, 2004 10:43 PM
traildawg
Sep 1, 2003 06:40 PM
