Quick Shift!
Old Jun 24, 2001 | 01:25 AM
Rock_me's Avatar
Rock_me
Quick Shift!
Hello Ford Owner's
I installed a B&M electronic
Shift Improver kit in my'96 E4OD tranny,it has two setting's #1.firm & fast,
#2.hard & faster,#3.off compleatly,,seem's to
work very well but will it
harm the tranny in any way?
Pump,seal's,,e.t.c.
Thxs,,Tony..
Old Jun 24, 2001 | 04:16 AM
cpnhgnjnky's Avatar
cpnhgnjnky
Quick Shift!
I thought the same thing to when I started reading about the shift kits. But as it turns out the more line pressure that is used the less slippage there is in the clutch pack which in turn means longer life. Hope this helps.
cpnhgnjnky
95 F150 4X4
Eddie Bauer super cab
lifted flomaster etc etc etc
Old Jun 24, 2001 | 05:53 PM
otto's Avatar
otto
Quick Shift!
Alot of people I have talked to have had the plug in shift kits fry there trannies, but dont take my word for cuz I dont actually know, all I have is heresay but not good heresay !
Old Jun 25, 2001 | 09:15 AM
slikness's Avatar
slikness
Quick Shift!
I've had the good fortune to have 3 trannies rebuilt over the past two years (in 3 different vehicles). My tranny mechanic put the B&M shift kit in all three because he likes the solid shift and limitations on clutch slippage. The last one was in my daughter's C***y Lumina with a wimpy V6 and it runs great.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Jun 25, 2001 | 06:24 PM
traildawg's Avatar
traildawg
Quick Shift!
I've had the B&M Shift Plus in vor over 2 years now and no signs of problems. I usually only turn it on when out wheelin as the shifts are a bit to firm for my liking....especially the 3rd to 4th shift.
Jim
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Pro-Comp Stage II Lift w/35's
Auburn Pro-Series Diff. w/4.30 gears
http://www.ProjectTrailDawg.com
Old Jun 26, 2001 | 07:20 AM
mc_1_2_3's Avatar
mc_1_2_3
Quick Shift!
I would bet that people having problems with a shift kit put them in hoping to fix a tranny that was already too far gone.
Old Jun 26, 2001 | 11:57 AM
jim henderson's Avatar
jim henderson
Quick Shift!
Just personal opinion based on having shift kits put into two vehilces over the years.
I have not had any failures with the internal shift kits. One kit was for a Dword "hot rod" with very firm shifts and high stall converter. The other is in my 94 F250 4x4 460 with E4OD for towing purposes. Both trannies were rebuilt while the kit was installed.
I have heard that if you go for the very firm setting you might have some problems with the drive train such as stress on rearend, engine, tranny, drivetrain mounting points etc. All depends a lot on how you drive too. If you drive "normally and don't go too wild with the kit I think everything will be fine. The shifts can be a bit "snappy".
The word of warning I will give is that some of the time you might not be in the mood for the snap that a lot of these kits give. Kind of fun at first but sometimes the occasionally jarring shift may be irritating.
I used the kits because I needed better shifting for a "hot rod" or I tow a lot and wanted more durability and a better shift pattern for towing.
Another warning is that some of the "race only" kits will allow you to drop your tranny into any gear you want at any speed. Tons of excitement if say for example you accidentally drop it into first on the freeway at about 70mph, been there done that, never again. Don't know if this applies to Ford trannies.
Good Luck,
Jim Henderson
Old Jun 28, 2001 | 06:11 AM
Rock_me's Avatar
Rock_me
Quick Shift!
Thank's for all the feedback fella's,keep on a 'Fordin....
96 F-150,5.8,E4OD,3.55 Lim,
JBA,Dynomax,BellTech,Hypertech,
Sir Michael's,Trenz,Toucan,
B&M,K&N,Soon to be AFS Lightning wheel's 18x9.5/5.5,Goodyear
Eagle F1 GS,Gosh! I love my
Truck!
Tony.....
Old Jun 28, 2001 | 09:31 AM
hokeyson's Avatar
hokeyson
Quick Shift!
1tjizzle
Sep 4, 2012 08:14 AM
smash fascism
15
Apr 27, 2011 01:31 AM
Tony1790
16
Mar 17, 2006 09:20 PM
Badford
Jan 16, 2005 08:32 PM
teebee
Jul 13, 2001 07:08 PM
