deeper and louder
Old Mar 10, 2005 | 07:55 PM
FFighterStu's Avatar
FFighterStu
deeper and louder
I have a 2003 F150 with a 5.4L V8. About a year ago I had a Flowmaster 40 put in and the rest of the pipes are the same. I gotta say that I'm not really pleased with it. While sitting in neutral it sounds great, but I'm looking for something that will be louder and deeper without losing any HP or Torque.
Any suggestions?
Old Mar 11, 2005 | 03:12 PM
fordfan302's Avatar
fordfan302
Flowmaster 1 chamber race muffler will do the trick
Old Mar 12, 2005 | 01:00 AM
Monty06's Avatar
Monty06
take out the cats and just add striaght pipe
or add your flow 40 .
Old Mar 13, 2005 | 10:11 PM
homer4.2's Avatar
homer4.2
that'll kill the high end.
What exactly is your setup now?? You just took the stock muffler off and replaced it with a FM40? If this is the case.. I would either
a) cut two of the cats off(it should have 4) and then put 2 flowmaster single in/single out on the dual pipes-that would be loud while still giving you enough back pressure to support you with HP.
b)take the flowmaster or flowmasters off, i dont know how many you have on there. And just run your exhaust with 4 cats and straight pipe the rest of the way out.
Those are two good setups in my opinion, where you wouldn't lose HP or hurt your motor..that yet would still make your truck LOUD.
Old Mar 14, 2005 | 05:38 PM
kens64's Avatar
kens64
Please read a little about backpressure. No engine needs backpressure. Want backpressure? weld a plate ovet your tailpipe and drill a 1/4" hole for the exhaust to flow through. That should make your truck run real good It doesnt support HP, it kills it.
And straight pipes will NOT kill your "high end". Thats actually the first time I have ever heard that. Usually people claim it would kill low end torque, which it really doesnt, or so little that you would not notice. Depends on pipe size. Go check out some dyno plots on any engine you can find on the net. There are thousands, and they will show you proof on either account. Neither will "hurt" the motor either.
Deeper- place the mufflers as far foward as possible. The more pipe after the mufflers, the deeper the sound will be.
Also you can use larger pipe after the mufflers. That really deepens the tone. Dont go stupid on size, and exhaust velocity will not be hurt. A size or 2 bigger is all you need.
Louder- Cut the rear cats off. Get headers. Both will do the job.
Old Mar 14, 2005 | 06:21 PM
mtt_e's Avatar
mtt_e
Flowmaster seems to be what everyone likes around here. If you dont like the Flowmaster then try a different name. But one bit of advice ill give ya is dont go with Magnaflows. Whatever you do let me know how things go with it.
Old Mar 14, 2005 | 06:25 PM
fordfan302's Avatar
fordfan302
the man knows what he talking about.....those mufflers arent worth anyones money
Old Mar 14, 2005 | 06:31 PM
kens64's Avatar
kens64
Why is that?
Old Mar 14, 2005 | 06:33 PM
fordfan302's Avatar
fordfan302
Originally Posted by kens64
Why is that?
mainly because they dont sound good, and they definately arent loud enough....the only good thing you get from magnaflow is a nice shiny finish
Old Mar 14, 2005 | 07:06 PM
kens64's Avatar
kens64
I will agree with you about volume, but I guess we will disagree about how they sound
Old Mar 15, 2005 | 04:29 PM
mtt_e's Avatar
mtt_e
The magnaflows have baffles in them that slow down the airflow. I would much rather buy something that sounds good and doesnt take power away.
Old Mar 15, 2005 | 06:05 PM
kens64's Avatar
kens64
Depends on the model. The Magnaflows on my truck are straight through.
Old Mar 15, 2005 | 07:03 PM
akford351's Avatar
akford351
Flowmasters have baffles. Magnaflows are straight thru.
1925mosin
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Aug 6, 2013 03:17 PM
GWTF150
1997 - 2003 F150
Jan 25, 2009 03:21 PM
bruno6491
Feb 16, 2008 03:29 PM
TallPaul
Exhaust Systems
Sep 15, 2007 12:01 AM
bertcakes
30
May 22, 2004 09:36 AM
