4x4 problem?
Old Mar 10, 2005 | 01:23 PM
Lazy K's Avatar
Lazy K
4x4 problem?
Went to see a `97 Explorer, thinking of buying it. Took a drive. First problem was the 4wd selector **** was broken and light on dash said it was in 4L. Using grips managed to turn switch to "automatic" position and light went out. Then drove OK untill I was reversing when there was a thump from the rear susp.- looked but could see nothing wrong. Is there a transfer case problem? What do you think?
Thanks.
Old Mar 11, 2005 | 10:49 AM
njf207's Avatar
njf207
From what you say its most liley the front end comming out of four wheel when you are backing up mine did some thing like only mine did it when I came to a stop and it would come out I hade te transfer case rebut and took the problem away hope this helps
Old Mar 11, 2005 | 01:01 PM
Lazy K's Avatar
Lazy K
Thanks for reply. Showing my ignorance here but I thought the Explorer was 2wd for road use. Is it full time 4x4?
Thanks again.
Kelvin.
Old Mar 11, 2005 | 01:12 PM
njf207's Avatar
njf207
Smile
No the front end is always in as far as I know and it should never come out its controled my clutches and other stuff that I dont really understand yet and when it comes out that means that either on of two things are happening the case is worn so badly that its letting itself come out or the clutches in the case are worn and not hold properly. all this makes the auto function possible that way there are no hubs to engage and the transfer case controls the front end completly any thing else I can help with the let me know
Old Mar 12, 2005 | 08:39 AM
Lazy K's Avatar
Lazy K
Thanks for reply. That gives me a better understanding of the system. It also gives me a lot to think about before I would buy this Explorer!
Thanks again, Kelvin.
Metz22
May 7, 2016 11:42 PM
JJ Welch
Nov 23, 2015 07:35 PM
trucktech
May 19, 2012 01:34 PM
floor monkey
1983 - 2012 Ranger & B-Series
Jun 17, 2009 07:50 AM
roadblade
Jun 15, 2009 10:11 PM
