97 ford explorer help
Old Nov 23, 2015 | 10:24 AM
JJ Welch's Avatar
JJ Welch
Exclamation 97 ford explorer help
headlights went off and hasnt reset itself and now the high beams arent on and i installed a new set of fog lights but it dont think the new fog lights are the problem What can i do to fix the problem
Old Nov 23, 2015 | 12:31 PM
shorod's Avatar
shorod
Welcome to the forum!
I don't understand your question well enough to offer suggestions on how to fix.
Are you saying that the headlights no longer work/light up, both low beam or high beam? Did you install the new set of fog lights just prior to this happening, or as a result of the headlights not working? Did you just replace the bulbs, or the entire fog light assemblies? If complete assemblies, did they use the factory wiring or did you run new wires?
Do you have a test light or multimeter that you can use to confirm whether or not you are getting power to the light sockets, and to confirm a good ground?
-Rod
Old Nov 23, 2015 | 03:40 PM
87 XLT's Avatar
87 XLT
When i sold my 97 i hung onto the factory diagrams, but like Rod said i'm also not sure exactly what the problem is. If your "flash to pass" is also not working check interior fuse 33 it's a 15 amp mini. Does this have autolamps?
Old Nov 23, 2015 | 04:19 PM
JJ Welch's Avatar
JJ Welch
it happened after i put the new fog lights on
Old Nov 23, 2015 | 04:20 PM
JJ Welch's Avatar
JJ Welch
i checked it and the high beams are back on but not the low beams
Old Nov 23, 2015 | 06:34 PM
87 XLT's Avatar
87 XLT
If you had factory fogs, i could tell you more. Check interior mini fuse 4 & 8. 4 is wired to
the drivers side low beam & 8 is wired to the passenger side, both are 10 amp.
Old Nov 23, 2015 | 07:35 PM
85e150's Avatar
85e150
Disconnect the new fog lights. Recheck any wire that you tapped into, connector you fiddled with etc, and check the fuses, relays, fusible links etc.
Once you have all that square and your lights work, rewire your fogs through a new circuit with it's own relay.
Serving suggestion..
cyncwby
Jan 3, 2017 01:46 PM
Vijay
Aug 23, 2014 10:42 PM
texas4x4
Jan 9, 2014 12:03 PM
4.0 Beast
Oct 28, 2006 12:33 AM
