Engine Problems- PLEASE HELP
Old Mar 17, 2005 | 06:39 PM
Gerry Lutz Jr.'s Avatar
Gerry Lutz Jr.
do check your thermostat they cost like 2 dollars and takes like 10 mins to do put in + if you have 1900000 miles its no telling how long its been since it were changed if it were. I had a thermostat in mine that was probably was probably original off a 1988 efi rusted to hell and wouldnt open more than a 1/16 of a inch and i gurantee your engine could be running cool if that were your problem. Also another thing while your looking at the thermostat make sure its for stock spec some people try to run cooler thermostats because of aftermarket fans and so on but u dont want to stray to far from stock temp for a thermostat or you will not have proper combustion. Anwyayz this is just from my limited experience im only 16 so take my words lightly, but i do gurantee this could be the reason and only takes a few mins to check and fix so make sure you get rid of that 2 dollar possibility before you get to more time consuming and more costly ideas.
Old Mar 18, 2005 | 12:09 AM
Judson4.9L's Avatar
Judson4.9L
I'll definatly check on that thermostat, thanks for the advise. I will tell you how it all works out.
Jared96f150
May 27, 2013 09:58 AM
tristpeyt
Apr 8, 2013 02:10 PM
mitch1500
Jun 24, 2010 04:43 PM
TheMech
16
Dec 8, 2008 12:57 AM
not a ford man
16
Jan 14, 2007 01:19 PM
