Sponsored by: Real Truck
Front sway bar links
Old Mar 9, 2005 | 08:47 AM
mizzitch's Avatar
mizzitch
I have a 1999 F-250 4x4 with x code springs that I put in to level it. The links I have now are a little too short. What is the best fix for this? Are there adjustable links out there that have the rubber or poly bushings? Or are spherical joint adjustable links reliable in MN? Will they affect ride quality?
Are the newer factory links with the bigger bushing area better? - the ones that do not seem to have any rubber in them.
Old Mar 9, 2005 | 09:52 AM
DCSpecial's Avatar
DCSpecial
I don't know of any adjustable sway bar links......the lift companies do have longer links available though.
Not sure how well the spherical bearings would hold up.....they transfer more vibration than a rubber or poly bushing.
If yours are too short you can flip the upper mount from inside the frame rail to under the frame rail.
Old Mar 9, 2005 | 10:10 AM
mizzitch's Avatar
mizzitch
ORU says that the flip of the brackets adds 5" that's a bit much - I probably only need an inch to two inches. Do you think since the sway bar has bushings to the axle the bushings do much on the links? Thanks
Old Mar 9, 2005 | 05:43 PM
DCSpecial's Avatar
DCSpecial
Yeah, flipping the mounts definately makes up for more than 1-2".....5" seems like a bit much to me though. I flipped the mounts when I had a 4" lift and it worked out well.
The bushings allow for "flex" during supension travel.
Old Mar 9, 2005 | 06:10 PM
beano's Avatar
beano
just cut the links and weld in a longer section.
Old Mar 9, 2005 | 06:13 PM
FAB150's Avatar
FAB150
For my 8" lift I just cut the eyeholes off each end and put in a whole new peice that was longer and bent like the factory one.
Old Mar 9, 2005 | 07:36 PM
mizzitch's Avatar
mizzitch
yeah i think i will probably section them since there does not seem to be any aftermarket for my application.
Old Mar 9, 2005 | 07:47 PM
jetjock16's Avatar
jetjock16
this is what i did, cut and rewelded in a new section.. it worked for about 3 months, it broke this weekend on one side and i just went ahead and ordered the correct ones from EDGE.. they sell them in aftermarket lengths.
Old Mar 9, 2005 | 07:59 PM
beano's Avatar
beano
how did you weld it?
Chevmn56
Jul 26, 2013 08:02 PM
rbhug
Nov 12, 2012 12:04 PM
rbhug
Dec 1, 2010 11:11 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 16, 2006 01:21 PM
War_is_my_Shepherd
Dec 13, 2004 07:22 AM
