Greaseable Sway Bar Bushings and End Links
I have a 2002 F350 4x4 CC 7.3 i am wanting to change the sway bar bushings front and rear to poly and I want greasable bushings to avoid the squeking that you get with these bushings alot of the time. I would like to change the end links to poly too i realize these wont be greaseable. Has anyone done this what was the outcome and where did you buy the bushings. Also does anyone know the size of the front and rear sway bars and the length of the end links????
Thanks in advance
Thanks in advance
Mine started creaking and squeaking at 60K miles. I tried greasing them twice, but noise came right back after 4-5K miles each time. The sway bar is not supposed to turn in the bushing. The bushing is supposed to flex.
I bought new ones from Ford and glued them to the sway bar with urethane glue when I assembled them. I also put a black plastic spacer about 1/8" thick between the frame and the bushing. Not a peep since (now at 174K miles.) Also restored the "new" feel to the suspension, which hasn't gone away as the bar has never turned in the bushing.
The swaybar does rotate inside the swaybar to frame bushings. When the front end bounces over a speed bump or a dip on the hiway. Just watch that bushing as you lift the front bumper with a floor jack, while the tires are still on the ground.
The same thing happens on the rear swaybar as ride height changes and the hellwig comes with grease to keep it from squeeking.
Thanks for the input I think!! Lol. Ill clarify I have 122K on the original bushings, they are soft and show a 1/8" gap between the bushing and the bar. It has a lot of lean turning a corner. The originals do not squeak.
The poly bushings use to squeak back in the day. Not sure if they do still. A stiff bushing will give it the stiffer ride and less lean when turning.
Guess ill have to re think the bushing thing. As for the ride the bushings on the sway bar have no effect the ride smoothness. If I wanted a smooth ride I'd get a chev
on
I wouldn't want greasable ones in there even if they cost less.
I got my end links form them and they come with grease zerks and everything also they are powder coated so they wont rust! The stock bushings are crap I started getting the clunking about two years ago so I had new end links put on and they starting to clunk again about a month ago but I ended up replacing them with the PMF ones when i lifted my truck.
