Front end conversion. Expy to 'gator.
Old Mar 7, 2005 | 09:45 AM
nismoz21's Avatar
nismoz21
i have a 99 expedition and was told that a 99 navi front will bolt on is this true and has any1 done it????
Old Mar 7, 2005 | 04:33 PM
78Explorer's Avatar
78Explorer
Sure...it will probably bolt right on, but if you want it to match up properly, you're going to have to swap a LOT more than just the front end - the Navigator has different side trim that starts at the front end, and continues completely around the vehicle. Not to mention the hood, bumper, fenders, etc. I wouldn't do it. It'd be less expensive and alot less trouble just to buy a Navigator if you want that look.
Old Mar 19, 2005 | 06:49 AM
fordsuvparts's Avatar
fordsuvparts
Thumbs up Navigator Front end
Yes if just bolts on but there is a little more work involved in making it look good.
I have done it 2 times now, look in my gallery at my 2002 f150 supercrew.
I just finished the conversion and I think it look really trick. I can give you detailed help if you are interested in doing it. I also know the part numbers from ford that you will need. I even have a few parts left over from my last couple of projects. I also had a matching 1999 Navigator that was the same color.
Good luck.
Kirby
jgilrfr
Aug 4, 2015 03:32 PM
Walleye Hunter
Jul 25, 2014 06:17 AM
99 f250 7.3
Nov 24, 2013 01:49 PM
jhemr
May 13, 2007 11:31 PM
