Sponsored by: Auxito
Stock Foglights
Old Mar 6, 2005 | 11:45 PM
TransXtreme's Avatar
TransXtreme
Stock Foglights
Does anybody know how to rig the 2002 f-150 so that u can have just the parking lights on with the foglights? How can I do that?
Old Mar 7, 2005 | 06:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Mar 7, 2005 | 07:24 AM
Johns9163's Avatar
Johns9163
Your truck's foglights are wired to the headlight switch. If you wish to have the foglights come on with the parking lights, you will need to pull the switch, use a volt meter and check to see which wires are for the foglights. You will need to cut and splice the stock harness, which I do not like to do. Another alternative is to wire another switch for the foglights and disconnect them from the headlight switch, again, you will need to cut the harness. Those are the two options you have that I am aware of.
Old Mar 7, 2005 | 07:38 AM
mayhelm's Avatar
mayhelm
If it were me, I'd do what John said, only I would add switch that was powered by the parking light. When switched on, the fogs would come on with the parking lights. But leave the fogs wired to the light switch so they could be used the regular way when the added switch was off.
Old Mar 7, 2005 | 03:57 PM
lm1d's Avatar
lm1d
You can have a hard time passing yearly inspections with that setup.
Old Mar 7, 2005 | 10:51 PM
mayhelm's Avatar
mayhelm
It should pass inspection. Their not really fog lights ( which in this state can't be on without head lights). Their really aux driving lights.
Old Mar 8, 2005 | 07:00 AM
christaylor's Avatar
christaylor
https://www.ford-trucks.com/forums/s...d.php?t=234912
Here is a article on how to mod the switch.
Good Luck
Old Mar 8, 2005 | 01:42 PM
TransXtreme
Thanks Chris!
Dean
2002 FX4
Old Mar 8, 2005 | 01:52 PM
BillyBob69's Avatar
BillyBob69
TransExtreme....I used the instructions on that site and it worked great for me. Nice to use em when you want and not when "they " think you want. I know there are some laws about them but its not like I am blinding anyone with em.
