Floorboard reconstruction
Old Mar 6, 2005 | 06:46 PM
tip49's Avatar
tip49
I've read the forums on floor repair; I'm undecided on whether the welds will be butt or lapped joints.
I am considering leaving a 1" lip around inner edge and around transmission opening of cab to suppport the repair panel, I am using 14 ga for added strength
and thinking of placing it on top of the "lip" left for strength. Will the overlapp cause future rust issues?
What means of clamping the repair panel to cab is recommended, I currently only have 6" C clamps
Tom
Old Mar 6, 2005 | 07:13 PM
LEckart's Avatar
LEckart
tip49-
I recently repaired the bottoms of my doors and a buddy convinced me to use panel achesive for the outer skin. I am pretty impressed with this stuff. You may want to check into it for your floor panel repair, especially if you plan to overlap the joints. They make different adhesives for different applications so you need to check with a reputable auto paint supply store to see what is recommended . I used the Duramix brand made by 3M so they probably have info on a website. It also acts as a sealer in the joint to keep corrosion out. It is not cheap but saves you a lot of time not having to grind welds or worry about heat distortion. You will need to purchase the applicator tool which is a dual piston caulking gun type apparatus. Both the tool and adhesive will probably run you +/- $100. If you have a buddy repairing similar items you could share the cost of the tool. Good luck. 56FUN
Old Mar 6, 2005 | 07:42 PM
Scot's Avatar
Scot
I just put a floor in the back of my '78 SC. I layed he new over the old and cut both with the plasma torch. That left a almost zero fit seam to MIG up. Welding went relatively quick with minimal hole chasing and warp.
I worried about rust forming in the lap area.
p2 angel
Sep 4, 2014 08:59 PM
chriscris
Mar 28, 2013 02:47 PM
wgking
Mar 25, 2004 05:28 PM
ymurf
Feb 18, 2004 06:22 PM
sigtauenus
Paint & Bodywork
Oct 25, 2003 07:46 AM
