no turn signals
Old Mar 6, 2005 | 02:22 PM
liljase's Avatar
liljase
no turn signals
I have a 1986 F150 4X4 with a 302 and4 an automatic.The problem I am having is I dont have any turn signals or brake lights.The headlights and taillights work.Any ideas what could be the problem.Thanks in advance for any input.
Old Mar 7, 2005 | 03:39 PM
73Custom's Avatar
73Custom
First check the fuses. Read through the brake light tech artcle - link at top right of page. The article has steps to test/repair brake lights and blinkers on a '70s pickup. The wire colors will be different, but the parts and testing will be the same for your '86.
Marty
Old Mar 7, 2005 | 06:14 PM
Franklin2's Avatar
Franklin2
The turnsignals don't even come on solid without blinking? If you find you have voltage at the brakelight switch on the pedal, and you have voltage on this same wire up at the turnsignal switch in the column, then I would lean toward the turnsignal switch being bad.
sierra308
Oct 1, 2010 03:27 AM
Duke78
Jan 17, 2010 04:58 AM
tdon11
Apr 29, 2009 07:50 PM
jbs03ranger
Jun 7, 2007 08:28 PM
