Trailer hitch/electrical problem
Old Mar 2, 2005 | 04:38 PM
Mello reel's Avatar
Mello reel
05 150 XL with V-6. Can't find a hitch bar to fit. bought one for an 04. dealer said it would work. wrong? Has a damper on the 05. also I hooked up a 6 disc changer to acc fuse. now the wipers and AC keeps cutting off? Is there a wire I can tie the accessory line into W/O it kicking off?
Old Mar 2, 2005 | 04:46 PM
MTurner2003's Avatar
MTurner2003
I work for U-Haul, and if you you mean the "receiver" as the hitch bar, try given us a call. Put 2 in an 05 150 yesteray. As for the wiring, try your horn, you'll have constant power, but the only way the horn can go off is you pressing it on your steering wheel so you shouldn't have the problem of anything tripping. Although make sure the fuse is strong enough, or it will just blow. That's my advice.
Old Mar 2, 2005 | 05:46 PM
Missouri Mule's Avatar
Missouri Mule
Etrailer just notified me that they have the hitch that will fit the ones with the damper. I have one and my order is on the way.
If the hitch is not designed with the damper, then it WILL NOT work. Take it back.
Old Mar 4, 2005 | 03:56 PM
Mello reel's Avatar
Mello reel
Hey Guy's thanks for the quick replies, and answers.. I have called U-Haul several times, and when I get someone who can understand my question they tell me to use the 04 it will work. Wrong. I called back and they said they don't have one for an 05???? Will try again.
Mello.
Old Mar 4, 2005 | 11:49 PM
MTurner2003
LoL sorry that's not working out for you... I'd help ya out if you were in Ohio!
Old Mar 6, 2005 | 06:59 AM
Mello reel's Avatar
Mello reel
Thanks Turner, but I'm in Savannah, Ga. Long ways from you!!!!!!!!
cherokeexj32
Jul 26, 2014 02:02 PM
ithaca1230
Nov 30, 2013 02:07 PM
1966Tbird
Nov 22, 2008 12:13 PM
Helmut
2004 - 2008 F150
Jan 25, 2006 06:19 PM
