bad wander
Old Mar 9, 2001 | 09:07 PM
KevinT's Avatar
KevinT
bad wander
Old Apr 26, 2001 | 07:46 AM
72f100's Avatar
72f100
bad wander
My brother has a 93 F-150 w/ a 4or 6" lift on it (were not for shure). Anyway when driving down the road it wanders really bad. It's not a gentle swaying between lanes it more of a jerky erratic pull to one side or the other. If you ever drove a car w/ the caster/camber way out of whack it feels similar to this. His radius arms are dropped appropiately and things look OK but it drives terrible. Is this common for these trucks when their lifted? He's pretty much given up on solving it but curiosity has the better of me. I'd really like to see this problem fixed cause he is family and all, and this problem is potentially dangerous.
Thanks
Jeremy(aka 72F100)
"Like a Rock"; on the sides of roads everywhere.
Old Apr 26, 2001 | 10:48 AM
whomrig's Avatar
whomrig
bad wander
[font size="1" color="#FF0000"]LAST EDITED ON 26-Apr-01 AT 11:57 AM (EST)[/font][p]Hi, this sounds like excessive toe-out to me. If this were my truck, it would be at the alignment shop now. I would also check the steering box for excessive freeplay. And checking tire pressure won't hurt. I am thinking there are larger-than-stock tires on this truck, so a good shop will be able to correct the problem.
my 2 cents....
Wayne
Old Apr 26, 2001 | 02:25 PM
72f100's Avatar
72f100
bad wander
We checked the toe w/ a tape measure (I know, it's not the best way to do it) and it seemed to be fine. That was my first thought as well.
Old Apr 26, 2001 | 08:05 PM
biggreen97's Avatar
biggreen97
bad wander
Well, this is my first post on here and I will try to help you out with it.
Depending on what type of lift that was used on his truck it is probably the lift blocks that lower the center section of the TTB front axle. Folks like Skyjacker and Superlift have perfected the art of making these things very stable but companies such as Tough Country and even Rancho have a problem with them flexing. It might not sound like it would cause a problem like that but just a very minimal amount of flexing in this area will cause the truck to wander dangerously. Hope this helps.
Old Apr 27, 2001 | 07:46 AM
72f100's Avatar
72f100
bad wander
The lowering brackets for the TTB were loose so My brother tightened them back up and welded them soild so I don't think That's the problem. He believes he has a trailmaster lift. His springs are (were) yellow though; I thought yellow springs indicated a superlift suspension. I guess I could be wrong.
Old Apr 27, 2001 | 09:24 PM
jakegypsum's Avatar
jakegypsum
bad wander
Has this truck been ran or 4-wheeled hard? Could be that the ball joints are worn or in need of lubrication. How about the tie rod ends or drag link? I have had drag links on several trucks cause bad wander over night. Radius arms could also need attention. Also, check the pivot points of both halves of the front axel. Bracket bolts can come loose. Just some thoughts. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old Sep 2, 2001 | 06:25 AM
TexasGuy001's Avatar
TexasGuy001
bad wander
Just my thoughts... Did you ever think of getting single or even dual steering stabalizers?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
