coil spring cushions
Old Mar 1, 2005 | 12:05 PM
tatonka's Avatar
tatonka
hello!
can anyone tell were i can get a new pair of
coil spring cushions! 65 ford f100! any help please!
thanks, terry !!!
Old Mar 1, 2005 | 01:59 PM
TremecGT's Avatar
TremecGT
What do you mean by cushions? Autofab sells a coil insert that acts like an airbag, basicly a softer progressive bumpstop. There really isnt any rubber cushions around the coils on these trucks.
Old Mar 1, 2005 | 02:25 PM
barry's Avatar
barry
Parts books don't show any cushions or inserts for the coil springs. They started with those in 1970 to reduce noise. They do list spring seats for top and bottom. Could this be what you're talking about?
Barry
Old Mar 1, 2005 | 02:31 PM
tatonka's Avatar
tatonka
hi!
my 65 ford f100 has a rubber cushion that the
coil spring sits on!
thanks, terry !!
Old Mar 1, 2005 | 02:35 PM
barry's Avatar
barry
Is it just one on each side? Is it top or bottom? Is it a thin rubber cushion with a lip around it to hold it in place? It's molded to accept the shape of the spring/ Or is it more like a doughnut that slips into the bottom?I've got the illustration here, just trying to clarify it.
Barry
Old Mar 1, 2005 | 02:39 PM
tatonka's Avatar
tatonka
barry!
it's goes on the bottom of the spring!
thanks for your help!
terry !!
Old Mar 1, 2005 | 02:44 PM
barry's Avatar
barry
OK, does the long bolt that holds the spring onto the axle go up thru it? If so, the parts books show an upper also.
Barry
Old Mar 1, 2005 | 02:54 PM
tatonka's Avatar
tatonka
barry!
it sits on top of the bolt that connects
the radius are & i-beam together! mine only has
one per side!
terry !!
Old Mar 1, 2005 | 03:06 PM
barry's Avatar
barry
Ok, I found it. It's part number C5TZ 5A307-A , they call it a spring seat. It's pictured as a round cushion with a step in it to center itself in the coil, with a hole for that bolt to go thru. A plate or washer and nut secure it all together. I can remember selling these in the 70's when I first got into Ford parts. It appears to be thicker than an inch and a diameter of the coil spring. If you want, click on my name and send a private message to me with your email address. I can scan the page from the parts book and send it to you. You can try NAPA for this by giving them the part number to cross over. Moog might also still make them. A good parts store might be able to track them down. I tried the locator for NOS Ford, but nothing came up. I can put it out there to see if someone might have it.
Barry
Old Mar 1, 2005 | 03:29 PM
Darren M.'s Avatar
Darren M.
I think I do. I just got back from the garage and looked. This looks almost like a pulley but the lower spring is wrapped around it, right? No rubber, just metal? If you can't find any let me know. These look pretty good, surface rust is all. My email address is stang at indy dot net.
Old Mar 1, 2005 | 04:30 PM
barry's Avatar
barry
Ok, I sent you an email where you can get some NOS.
Barry
Old Mar 2, 2005 | 11:43 AM
tatonka's Avatar
tatonka
barry!
thanks for all of your help!
thanks, terry !!
Old Mar 20, 2005 | 08:25 AM
Pistonhead's Avatar
Pistonhead
When I rebuilt the front end of my effie, I used High Pressure Heavy Duty hydraulic hose cut to the length of one coil, lubricated the bottom coil, then slid the hose over the coil "not easy", and left the last 1/2" of hose as overhang. The tops of the springs are clamped to the top spring perch.
After doing this, the bumps and rattles in the steering virtualy disappeared, and the ride feel is very much improved.
greagin
19
Apr 14, 2017 12:30 PM
firemedicE3
Apr 8, 2017 11:38 PM
2002exPSD
Jan 30, 2016 09:47 AM
86351wHOsupercab
Feb 5, 2014 08:55 AM
jjoyce
1997 - 2003 F150
Dec 10, 2006 07:22 PM
