i redid all the brakes on my 66 a year or so ago, complete with the front and rear rubber lines. I had my exhaust moved the other day to accomodate a bigger hitch and now I'm worried that if i load the truck to max that the exhaust may hit the rear line.
has anyone found someone that makes SS lines with that weird T fitting on it?
I wouldnt mind changing the front lines to SS also. Thanks
I managed to get a picture from someone off the street that wanted to put it on his site! Can't see the dirt in this pic, and yes that wiper is a slapper!
You don't want your rubber brake lines to touch your exhaust, even if they have the SS mesh around them. They are still rubber and susceptible to heat.
