Carb problem ?
Old Mar 1, 2005 | 07:28 AM
Edge Motorsport's Avatar
Edge Motorsport
Carb problem ?
Guys,
as you know from my repeated questions of random-ness ive just done a top end rebuild on my 360. heads were skimmed and rebuilt, new valves and seat seats etc...
well, after my first TIMING issue, the truck now fires up and runs, but it runs real fast.. so a back the timing off (dizzy goes counter clockwise ?) and it slows down...
Now my problem is, when i give it a rev then come off it, the revs drop down to 1000 then slowly fall off 700......500...300.....splutter .... dead..
It was doing this kind of thing before so im thinking its the carb. THere are 2 white screws with limiters on the front of the motorcraft 2bbl. What do these do and how do i stop it running like this ???
Many thanks guys,
EDGE
Old Mar 1, 2005 | 10:03 AM
Mike G's Avatar
Mike G
Well... You do not want to set your idle by adjusting your timing. Familiarize yourself with the datails of the carb and it's adjustments. Then set your timing correctly and start adjusting your carb. You probably need to rebuild the carb before you go through this as you state you were having problems previously. Adjust the air/fuel needles and idle as necessary to make all the goodies work together. No sence in putting junk back on a refreshed motor.
--Mike
Old Mar 1, 2005 | 10:44 AM
Edge Motorsport
this is true Mike, I'll have a look to find a rebuild kit for the carb over here.. or will a holley 2bbl fit these manifolds ?
EDGE
Old Mar 1, 2005 | 06:14 PM
754x4fordman's Avatar
754x4fordman
do you have a whistling noise before the stall? just wondering if mabey you have a vac leak somewhere... still got on the carb spacer with the nipple out the front under the carb? put your thumb over that vac nipple if its not already plugged... mabey the plug (hose and bolt) is missing? fell off during rebuild? i know that this nipple unplugged will cause the stall. just an idea.
Old Mar 1, 2005 | 06:21 PM
FORD352V8's Avatar
FORD352V8
Yes a Holley 500 2bl will fit on there, but you may want to upgrade to a 4bbl carb and intake, much more flow. The MC carbs are nothing to brag about.
Old Mar 2, 2005 | 02:00 AM
Hypoid's Avatar
Hypoid
All true! If you have the money to spend, a good choice to make.
Be aware that even a new carb needs to be set up and tuned.
I get the impression that you haven't done much with carbs yet. The ole 2bbl is a good one to learn on: simple, cheap, and easy to replace if you find a cracked/broken/worn out casting.
The last time I rebuilt my 2bbl I spent $10 on the kit and $15 on a gallon of Chem-Dip (reuseable). I already had compressed air, a vacume guage, and a manual to refresh my memory. If you don't have compressed air, aerosol cleaner is effective for "chasing" the passages after rinsing.
The best part is that I had the beast parked back on the street before my wife returned home.
For less than $100 you could be driving it this weekend and have a better understanding of how all the parts-n-parts work together.
Just some food for thought, Mike
Old Mar 2, 2005 | 10:58 AM
Edge Motorsport
good call, I haven't got the first clue about carbs, I come from a totally fuel injected throttle body background. I spend everyday just praying that the carb will carry on doing its job... there's no ecu for me to plug in to here ?!?!?!
from what can see on the carb there are only the 2 white screws to mess with, now all i gotta do is find out what they do, anyone ?
EDGE
Old Mar 5, 2005 | 01:18 AM
Bear 45/70's Avatar
Bear 45/70
The two screws on the down low on the front of the base plate of the carb under the float bowl angling out slightly are the mixture adjustment screws; in (clockwise) to lean the mixture out (couterlockwise) to richen. To start screw them in while counting turns until lightly seated then back out to 1 1/2 turns. They should have been close to that to start with. Then slowly turn either one in until engine stumbles the back out past starting point un til it starts to slow down the back to half way between those two points. Do the other screw. To adjust Idle speed make sure engine is warm and choke is off. Then on left side of carb(drivers side) is a screw on the throttle linkage. In will speed up, out will slow down. Can be adjusted prior to carb mixture adjust if rpms are above 800 (600 is better). Before you adjust carb set ignition timing to spec. This aint rocket science, real basic stuff. Any shop manual will have all the info you need. No money for a manual, then library will will have one. Go in and read, if need be copy a few pages and go do it.
Old Mar 6, 2005 | 07:53 AM
Edge Motorsport
thanks for the advice dude, but those 2 screws only turn about 7/8 of a turn, total. theres a limiter stopping it from turning a whole turn ? maybe thats all the adjustment i have ?
time to go read a book....
assuming a library over here in the uk carries a book on motocraft carb tuning
EDGE
Old Mar 6, 2005 | 12:05 PM
Bear 45/70's Avatar
Bear 45/70
EDGE
Just take a long pair of needle nose pliers and pop those worthless government interference in your life off and trash can them.
Dave145
Oct 6, 2016 03:56 PM
Kyre Searcher
25
Jul 29, 2016 05:30 PM
twigsV10
Modular V8 (4.6L, 5.4L)
Feb 12, 2016 12:04 AM
Steelheader87
15
Sep 16, 2015 10:47 PM
97powersmoke
Jun 30, 2015 07:07 PM
