Edge Insight shuts off while driving
Old Jun 29, 2015 | 09:43 PM
97powersmoke's Avatar
97powersmoke
I tried searching and found nothing helpful. I have a 96 250 and have an Edge Insight for gauges. Does everything it's suppose to except recently it will randomly shut off while driving. I can touch the screen and it will turn back on but once it finishes loading, it shuts off again. I called Edge and they reset the software in it but they said I may have a problem with my PCM not communicating with the OBD2. I know the OBD2 has power, unless it loses power for a split second and is back. Where do I start?
Old Jun 30, 2015 | 05:32 AM
Vertrees's Avatar
Vertrees
That is interesting. Have you made sure your harnesses are all still making a good connection. do you have any play when you jiggle the edge harness at the OBD2?
Old Jun 30, 2015 | 06:57 PM
97powersmoke
There is no play. Can anyone tell me how to find the wires running from the PCM to the port?
Old Jun 30, 2015 | 07:07 PM
97-psd's Avatar
97-psd
Something you may try if you have a friend who has a powerstroke is try it on their truck and see if it does the same thing. That way you can know for sure if it is the Edge or the OBD port
shangopat
Computer Chips & Tuners
Sep 14, 2011 07:09 PM
crf
2004 - 2008 F150
Apr 7, 2008 10:02 AM
pepito113
2004 - 2008 F150
Mar 15, 2008 11:20 AM
David1990
Jan 15, 2006 01:02 PM
