77 front end
Old Feb 28, 2005 | 10:20 PM
skunktruck250's Avatar
skunktruck250
Question 77 front end
hi
i have a 77 high boy and a 78 both f250. i was wondering is the front axle in the 77 heavy duty? cause the lock outs are much bigger then the 78. i heard that the bigger lock outs were better.
thanks jim
Old Feb 28, 2005 | 10:41 PM
30over's Avatar
30over
Hi Jim, Your 77 most likely has the Dana 44HD (Heavy Duty) where the 78 is the standard or light duty. My 77 Highboy now has a 44HD in it out of a 75. It use to have a light duty in it which was nearly trashed when I got it. Both are pretty good although there not as beefy, nor will they take the abuse that a Dana 60 will.
Someone will probably correct me on this but to my knowledge the difference in the 44 & the 44HD is the outers (hubs, rotors, calipers) which on the 44Hd are near equivalent to a Dana 60 but the stump is the same.
Old Mar 1, 2005 | 12:06 AM
FordPickup460's Avatar
FordPickup460
The regular 44 is high pinion, the 44HD is low pinion.
Old Mar 1, 2005 | 12:22 AM
5.8LiterImportEater's Avatar
5.8LiterImportEater
it could possibly be a Dana 60 low pinion. in '77 they had a low pinion Dana 60. On the front of the case there will be a 60F cast into the center section. I bet you have the 44HD, but I would check the case.
I should know about the low pinion 60 since I have one.
Chris
Old Mar 1, 2005 | 08:42 AM
skunktruck250
well the 77 is a low pinion im going to take a look for the stamp.
thanks
Old Mar 1, 2005 | 07:23 PM
Fordbronco69's Avatar
Fordbronco69
Infidel
Is the front axle closed knuckle or open? If its a closed Knuckle its the 44HD.
Old Mar 1, 2005 | 11:46 PM
skunktruck250
nope it is open knuckle. hey chris it does have 60F on the front right side.
what year has a closed knuckle?
Old Mar 2, 2005 | 01:23 AM
Fordbronco69
Infidel
My 74 F250 has a closed knuckle D44 HD. If youve ever seen those concrete delivery trucks 6x6's, they have the same type of axle but like....20 times bigger.
Old Mar 2, 2005 | 02:45 PM
5.8LiterImportEater
I have no idea what years had open knuckles but I thought you may have the rather rare 77 dana 60 low pinion. I have heard that these axles are weaker than the high pinion ones, but I can't see why that would be because it is the typical case, with the same spline count axles as the high ones, and kingpins...so I think it is a rumor. But thats the info I have heard on this.
Chris
Old Mar 2, 2005 | 02:58 PM
460f250's Avatar
460f250
OK, it's time to show my ignorance. I've heard "open knuckle" and "closed knuckle" many times but I'm not sure of the difference. Sure, one is open and one is closed but a little more description please.
Old Mar 2, 2005 | 03:44 PM
Fordbronco69
Infidel
Here are some pics of the Closed Knuckle Dana 44HD.
http://img.photobucket.com/albums/v6...9/S3010005.jpg
http://img.photobucket.com/albums/v6...9/S3010004.jpg
http://img.photobucket.com/albums/v6...9/S3010002.jpg
Old Mar 3, 2005 | 01:32 PM
nebechanezer's Avatar
nebechanezer
My 77 hiboy has a low pinion front end w/ open knuckle, does that mean its a d60?
Old Mar 4, 2005 | 12:23 AM
460f250's Avatar
460f250
Thanks for the pictures. That makes it pretty obvious doesn't it. I'll have to stop looking at rear ends and start looking at front ends, on trucks that is
Old Mar 5, 2005 | 09:59 AM
steveo420's Avatar
steveo420
i used spindle outers from a hd44 and installed it on a high pinion reg 44 to make a high pinion hd 44 for my high boy(u can do the same thing to the 1/4 ton 44's
Old Apr 26, 2006 | 01:18 PM
renopowers's Avatar
renopowers
One other diffrence, the axle tubes on the HD are thicker than the regular 44 so it's not quite a HP44HD axle. Still cool though.
I have a 75 D44HD with Drums right now. I'm looking for the most cost effective way to upgraded it to Disk. It has the closed knuckle king pin, so swapping spindles/hubs may be tougher option than with a regular ball joint, partly due the limited number of these axles in junkyards. I dont hold out much hope for finding this sytle with factory Disk.
I'm wondering if I can make a custom backing plate/caliper bracket, use the hub and rotor off an open knuckle disk model and call it good. Basicaly will the spindle accept a hub from a newer, disk break version 44HD?
<O</O
We'll see I guess.
-R<O</O
