Axle Code 86?
Old Feb 27, 2005 | 10:02 PM
mustange70's Avatar
mustange70
Axle Code 86?
Hey everyone i need some help on telling me what gear ratio i have in an 88 1 ton 4wd that i have a chance to get a hold of, the axle code was i belive 86 (could of been 88 too), but the front axle is a dana 60 and the rear is a ford 10.25"
Old Feb 27, 2005 | 10:37 PM
95X15's Avatar
95X15
88 manual says Dana 60 is on F350/10.25 is on F250and F350. No code 86/88 listed- axle code on door jamb will be 3 digits for 4wd with limited slip (3rd digit is 2). B9 is 4.10 5300# axle; C9 is 6250# 3.55axle; 69 is 8250# 3.55 axle; none of the other codes appear to match 88/99 listed above See if you can find a tag on front and rear axle and post what is on tags.
Old Feb 27, 2005 | 11:18 PM
mustange70's Avatar
mustange70
I wish i could go check the truck out right now but its 3 hours south of me.
Anyway the truck is an 88 f-350 Crew cab for sure, and the front axle is a kingpin dana 60, and the rear is a 10.25" stereling, that is what i know for sure, now i know that the last number was either a 6 (which is what i'm pretty sure it is) or it could be an 8, it could be a B9, but i am fairly sure that its not a ls rear, so if possible could you check the other possible ratios with a 6 or 8 thats a non LS, thanks.
Old Feb 27, 2005 | 11:49 PM
95X15's Avatar
95X15
29 is 5300# 3.55; 39 is 6250# 3.55; 49 is 7400# 3.55; no 6's or 8's in last (2nd digit) location. Al 4.10 axle codes over 3800 end in 5. If you can see the tag the ratio is on tag.
Old Feb 28, 2005 | 02:51 PM
mustange70's Avatar
mustange70
Thanks for the help, i'm thinking now that its either a B9 or 39, thanks again.
GASPIG88
Jan 16, 2017 04:23 PM
spooktn
1983 - 2012 Ranger & B-Series
Sep 4, 2016 10:29 PM
86f150step
Nov 27, 2015 06:30 PM
amchastain
Jul 23, 2005 09:44 PM
