radio bezel for cd player?
Old Feb 27, 2005 | 04:48 PM
6268f100's Avatar
6268f100
Smile radio bezel for cd player?
Does anyone know if the origional radio bezels are wide enough to be cut out and hold a cd deck? If not, what else have you done for a cd player install?
Any help would be appriciated.
Old Feb 27, 2005 | 06:24 PM
64 Bolt's Avatar
64 Bolt
I've done 2 installs in these trucks a 67 and a 71, and I normally bend the two tabs back (towards the front) and make my bezel out of .050 aluminum The measurements are 9" X 4 3/8" for the plate. then attach it to the dash using 4 stainless #8 screws and self locking nuts on the back. Then bend the tabs on the mounting cage to suck it up tight to the aluminum plate. Put one of the strap things on the back to hold the back up (optional if you use .050, cause it's pretty sturdy). I have brushed one and polished one, both looked pretty nice. That measurement above is for a 71', cause its tight between ashtray and glovebox.
Old Feb 27, 2005 | 06:25 PM
64 Bolt's Avatar
64 Bolt
Oh yeah, I did cut up an OE bezel once. It didn't look great, and it ruined a pretty good bezel.
Old Mar 1, 2005 | 05:21 PM
Steve_1970's Avatar
Steve_1970
64 Bolt can you give me a little more info on how that was done I want to put a cd player in and don't want to cut up the dash.
Steve
Old Mar 1, 2005 | 09:42 PM
64 Bolt's Avatar
64 Bolt
basically you'll be making your own bezel and mounting it over that factory recess and then just mounting the CD player to it. You still have to drill 4 holes in the dash though. To not touch the dash, I recomend going with one of those 2 knobbers with CD changer controls, and then put a changer in the glove box, or wherever you can find room. This would obviously be more friendly to the dash. I can probably send some pics of my install later this week (like sat or sun). .
Old Mar 3, 2005 | 11:54 AM
talisker's Avatar
talisker
I don't like messing with the dash since there is "no going back" I have found bezels on ebay at $5 -$15 dollars each. I put a CD in my 69 by bending back the tabs and cutting the two hole part out of the bezel off ebay. I did try making my own bezel years ago and was not real successful due to the wierd shape. After I cut up the bezel it made a real nice install.
Old Mar 3, 2005 | 02:07 PM
4xcrazy's Avatar
4xcrazy
L M C shows to have a replacement headliner w/radio opening made in it, and two speakers. no cutting on the dash. I'd check on this for an option.
Old Mar 4, 2005 | 03:03 PM
Steve_1970's Avatar
Steve_1970
Hey Bolt that would be great to see some pics of the after install. A few screw hole is one thing but cutting up the dash is another.
Steve
Old Mar 11, 2005 | 06:46 PM
6268f100's Avatar
6268f100
Thanks for all your input
Old Mar 11, 2005 | 10:31 PM
64 Bolt's Avatar
64 Bolt
I'll post some pics as soon as I get a chance, I am finishing one right now in a 71.
Old Mar 11, 2005 | 11:39 PM
ha2400's Avatar
ha2400
other option
I haven't done this to my truck yet (71 F100) , but i've done it to a few cars. You can mount a cd player under the dash, just fabricate a mount box with a metal brake in a |__| shape big enough to mount the box with sheet metal screws to the bottom of the dash. Then install your cd player. The vehicals i've done this to looked professional. Then seal off the old hole in the dash with cover that was used on the no radio option.
Aaron
Old Mar 13, 2005 | 04:04 PM
Steve_1970's Avatar
Steve_1970
I firgured out a way too. I used a mounting bracket from a boat where I work and hacked it up 'til it fit behind the dash then mounted the radio and bent the tabs back. I screwed this to the tabs and seeing the orignal radio bezel was kinda broke already I trimed that and all the shows is the face of the cd player. Very happy with the out come and have radio again.
Old Mar 15, 2005 | 06:41 PM
64 Bolt's Avatar
64 Bolt
I am not smart enough to put pics on here, email me and I'll send ya pics of my truck's install.
intruder1239
Feb 13, 2012 08:50 AM
danlee
Jan 25, 2011 08:18 PM
stein888
Feb 8, 2009 09:12 PM
Dallenx
Feb 10, 2007 12:34 AM
blackandsilverbronco
1978 - 1996 Big Bronco
Aug 30, 2004 09:36 AM
