Is it a problem?
Old Feb 27, 2005 | 09:48 AM
rmalottwtes30's Avatar
rmalottwtes30
Is it a problem?
on my 300 when I slam the gas it falls on its face, but when I slowly accelerate its ok, is this a problem if so whats causing it, what can I do to fix it, or is it suppost to be this way?
Old Feb 27, 2005 | 02:10 PM
johnsonswamp's Avatar
johnsonswamp
EFI or carbed motor? what year? whats changed before it started this? etc. need more information rather than "it just falls on its face"
Old Feb 27, 2005 | 03:11 PM
yaki69's Avatar
yaki69
if its a carb, its because its the puny 1 barrel.
Old Feb 27, 2005 | 03:18 PM
Southtowns27's Avatar
Southtowns27
If it's carbed, the accelerator pump in the carb likely went bad. With the engine off, take off the air cleaner and look down the carb. Work the throttle linkage, you should see a fair amount of fuel shoot down the carb. If you don't, the acc. pump is bad. Go to the local parts store and order up a carb rebuild kit. They're only about $20-$30 and will get you running good again. Good luck
Old Feb 27, 2005 | 03:54 PM
tetraruby300's Avatar
tetraruby300
Sounds like a timing issue to me. Is the advance hooked up to the dizzy?
1968bumpside
Mar 16, 2012 12:36 PM
SheenaMarie
May 29, 2008 12:24 PM
jpjahn
Jun 20, 2005 04:46 PM
dwbob
Jan 29, 2005 06:51 PM
Miketnf150
1978 - 1996 Big Bronco
Apr 4, 2003 12:37 AM
