Oil Pressure
Old May 29, 2008 | 10:07 AM
SheenaMarie's Avatar
SheenaMarie
Exclamation Oil Pressure
I have a big problem my truck has 65 pounds of oil pressure when its cold and when it gets hot it only has 2 pounds what could be rong with it????
Old May 29, 2008 | 10:12 AM
jason867's Avatar
jason867
My truck does the same thing, might be the gauge being old, might be just a tired engine.
Even though mine has no oil pressure when hot, it never starts complaining or ticking or doing anything out of the norm...
Basically I wouldn't worry about it unless you start hearing a ticking sound in the engine.
You could maybe improve it by using a heavier weight oil...
Old May 29, 2008 | 10:33 AM
SheenaMarie
Exclamation
i use 20 50 w and i put 2 qt of lucus i just rebuilt the motor the only thing i did not do was put a new oil pump i think i am going to try that and i have new gagues
Old May 29, 2008 | 10:52 AM
jason867's Avatar
jason867
get a high volume oil pump that will help increase pressure
Old May 29, 2008 | 11:35 AM
serviceguy's Avatar
serviceguy
Did you change the cam bearings when you rebuilt the engine? If you did the gauge and or pump is probably the problem if you did not change the cam bearings I would still change the pump and gauge first but the worn cam bearings in any engine usually have the biggest single impact on oil pressure.
Old May 29, 2008 | 12:24 PM
NOCO77's Avatar
NOCO77
High volume pumps do not increase pressure - 2 different things that are not related. As a matter of fact, most high volume pumps only provide more volume with no difference whatsoever in pressure - and this is desireable. Volume is the critical thing here anyways, as too much pressure can blow seals. Pressure is simply created by the amount of restriction in the oil paths.
What indicated (? to the OP) only 2 psi? Was it a real gauge? Even real gauges' resolution is questionable at such a low pressure (unless you checked with a pressure transducer and digital VOM).
Jayme Duty
28
May 26, 2019 11:38 AM
pickenspolitics
18
Aug 10, 2013 07:01 PM
IDIDieselJohn
20
Apr 19, 2011 11:15 AM
IDIDieselJohn
44
Apr 5, 2011 09:55 PM
BruceRH90
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 19, 2004 05:53 PM
