Sponsored by: Kumho
Brake Line Sizes
Old Feb 24, 2005 | 09:46 PM
KSever's Avatar
KSever
Brake Line Sizes
Went down to try and get the 89 F-250 4x4 started so I could bring it home after buying it for cheap and found out I need to replace the steel brake lines first. Was trying to reconnect a wire to the distributor and hit one of the steel brake lines going into the T fitting and it broke right off, I think mostly due from the rust. I am going to need to replace the steel brake lines but every place I look I need to know the diameter and length of every line. I am curious if anybody has a book that would tell me without having to take all these lines off first what size lines I am going to need. This would be for 1989 F-250 4x4 standard cab/ 8foot bed. Any help would be appreciated.
<!-- / message --><!-- sig -->
Old Mar 15, 2005 | 09:22 AM
guillermorivera's Avatar
guillermorivera
I don't know if they're compatible, but my 94 F-150 lines are 3/16 inch. You may also try inlinetibe.com, they sell brake lines and may be a god reference point to learn the appropriate size. Also, a Ford dealer may be a good source.
Old Mar 15, 2005 | 09:27 AM
guillermorivera
If you mean length, I think the ones from the master cylinder are 51" (due to the bends) available at Advance Auto Parts. From the front to the back however, you will need a 25' coil that does not include flared ends (the short lines already come flared). If the line that broke was badly rusted, the others are not far behind. Ask me how I know.
Old Mar 15, 2005 | 09:28 AM
guillermorivera
In my first post, I meant www.INLINETUBE.com
JeepGuy93
Apr 3, 2017 02:04 PM
rwelli1001
Oct 24, 2016 05:12 PM
Izera
1997 - 2003 F150
May 5, 2013 01:27 PM
Chaosracing
Aug 2, 2011 07:45 AM
GUNNERDOG
Dec 6, 2009 08:10 PM
