Brake Lines
1. What size lines? Looks like front two are 3/16", rear two over the axle are 3/16", and the rear line in the frame is 1/4".
2. What other things do you recommend doing?
3. Does anyone have tips to make the job easier?
We are removing the bed (2013 bed) to make things easier. I am thinking fuel lines and parking brake cable while the bed is off. I have stainless steel hoses from KLM performance and I am also planning on replacing the rear rubber hoses. Obviously I'm using nickel copper line. There shouldn't even be an option for other brake line.
https://www.klmperformance.com/ford-...nes-99-04.html
the hard lines are available prebent and terminated from motorcraft and can be had fairly cheaply from Rock Auto. Do them all straight back to the ABS unit. Don't cheap out. replace everything you possibly feel you can afford. it's worth it in just not dealing with the friggin rust. parts on our trucks are so cheap, anyway...
I would not recommend replacing the brake lines with stainless. there's no reason paying through the nose for SS lines when the stock ones will get you another 15 years, at least, anyway. Stainless is also a pain in the *** to bend, if you have to make adjustments.
What I'm mostly looking for is what lines pass through the framerail there, that would otherwise be inaccessible or difficult to access with the bed on.
Since I am removing the bed, I'd like this to be a one shot kill as far as maintenance in that area for the next decade.
