Another question on semi-routine maintenace
Old Feb 23, 2005 | 09:44 PM
jeffh's Avatar
jeffh
Question Another question on semi-routine maintenace
Another question dealing with how often I should get off my lazy behind and do "routine maintainence", or at least take my truck somewhere to have it done. And no, (knock on wood) I'm not having any problems with this...
OK, transmission, rear axle, brakes -- on a vehicle travelling <1000 miles a year, any recomendations on how often to change the fluids? Again, 1-2 times a year sounds excessive and 10000 miles seems too long (reco'd by the owners manual). Let's assume all levels are checked on a regular basis...
Also, I guess there is no way to change the fluid in the steering gear case, other than tearing it apart?
Old Feb 24, 2005 | 11:40 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Jeff,
Seems to me there was a discussion on this recently. There are differing opinions on this but if it were my truck, I'd change the oil and filter twice a year (once a year if you use Mobil One or other synthetic) and check the transmission fluid and rear axle when you do the oil change. I would not worry about changing the fluid in the steering gear and I'd want to look at the brakes about once a year assuming there are no symptoms of brake problems.
Vern
Old Feb 24, 2005 | 01:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Without products of combustion, all you need to worry about is condensation. The amount of that present will vary greatly depending on your weather/climate. In theory the little "rattle caps" that vent the axle and trans keep atmosphere out, but it doesn't take much dirt to hold them open. If you take the truck for a good drive every month, that will really help. It takes a lot longer to get a diff or trans hot enough to evaporate any condensation.
I would worry most about the brake fluid. It's amazing how much moisture the fluid will suck out of the air, even with a good cap on the master. If you're in a wet area, I'd bleed them at the start of every season.
Old Feb 25, 2005 | 10:22 PM
jeffh's Avatar
jeffh
OK, thanks for the replies. The consensus seems to be a little expense now is better than major headaches later...
garydmundy
Dec 13, 2012 08:46 AM
ExpySport
13
Oct 5, 2009 08:39 AM
Aaron77
Nov 30, 2006 06:23 PM
Pastmaster
Jan 18, 2000 07:41 AM
