Tranny Flush debate
Old Nov 27, 2006 | 02:27 PM
Aaron77's Avatar
Aaron77
Tranny Flush debate
I have heard varying opinions on the "health" of flushing the transmission vs. just routine filter/fluid replacement. Any opinions, and how often would you recommend tranny maintainence? My 2000 V10 has 125K
thanks
Old Nov 27, 2006 | 03:24 PM
VaSheriff's Avatar
VaSheriff
I have heard way too many horror tales from people who have had the total flush done. It seems to do more damage than good.
I will stick with the old fashioned method myself.
(Do you suppose the newfangled total flush came to be so as to induce more failures and repairs? )
Old Nov 27, 2006 | 04:26 PM
madhatch's Avatar
madhatch
old school, rulez
Old Nov 27, 2006 | 08:14 PM
MadMedic20's Avatar
MadMedic20
I had mine flushed at a Ford dealer about 4,000 miles ago. So far so good.
Old Nov 27, 2006 | 10:25 PM
SSGG's Avatar
SSGG
I self flushed mine several thousand miles ago, super easy to do by yourself and when you see all of that dark fluid coming out you will know why you did it. The 5 or so quarts from a filter change is just the tip of the iceberg.
Wes
Old Nov 28, 2006 | 07:15 AM
MarkMoore's Avatar
MarkMoore
I'm assuming that you drained the tranny through one of the cooling lines, while adding fluid at the same time. I don't think that is what Aaron was referring to - I know that is a safe method.
Like Aaron, I've heard horror stories of shops using a pressurised/mechanical flushing system to force out the fluid, floowed shortly by a tranny failure. I've been told that this is because the flush system loosens debis from the fliter and said debis ends up in the converted, causing damage.
I know some shops that praise the process and have never had a complaint. So I think it could be one of those urban legend where it did, in fact, cause a problem in a vehicle that was probably already have tranny issues - but that is just my belief.
I prefer the method of dropping the pan, changing/cleaning the fliter, reassemble and draining the converter thru a cooling line while running the engine and adding fresh fluid.
Old Nov 28, 2006 | 10:47 AM
weekendwander's Avatar
weekendwander
I had a trans shop give me the best advise. The flushes are not causing the tranny to fail. The problem is that people don't maintain the transmission and then start having problems. They then talk and someone says, you haven't had it flushed, go have it done.
They walk into a shop (or maybe a Jiffy lube and tell they person they want a tranny flush, not I am having issues . . .
After the flush the tranny blows. They seem to forget why after XXXX thousand miles they had it flushed. It didn't blow up "because it was flushed" it was already gone because it wasn't maintained to start with. The flush may have caused it to fail a little quicker but the fact that it had worn out oil for the last XXXX thousand miles is what caused it to go out.
It makes perfect sense to me. I also had a mechanic at a trusted tranny shop tell me that they would not change fluid on a vehicle that had over 100K on the orginal fluid. They said the combination of the fact there was probably already a problem and that the new clean fluid did tend to cause some seals to leak made the jobs more problems than they were worth.
Old Nov 28, 2006 | 11:32 AM
aklim's Avatar
aklim
Isn't it like Biodiesel? I hutched and harpooned my tank and it was clean. However, if there was crud there and it messed up the filters, I'd probably blame it on Biodiesel and it would be true. I have serviced my trans every 30K or so and I use good synthetic so there is no buildup.
Old Nov 28, 2006 | 12:15 PM
Casey's Avatar
Casey
EXACTLY! That's why flushing the trans has developed a bad name. There's nothing in the flush process that can cause problems.
There is also no such thing as a power flush or backflush. Most of the machines do use the pressure from the outgoing fluid to push new fluid back into the trans, but it flows the same direction at the same or lower pressure as it would if the trans were operating normally.
Old Nov 28, 2006 | 12:36 PM
aklim's Avatar
aklim
I used to flush my 700R4 every other year. One year filter, one year flush.
Old Nov 28, 2006 | 04:58 PM
madhatch's Avatar
madhatch
on this subject I say this, lexus uses a power flush sytem on the car I drove until my x. I am an active member of the board and they never complain about it tearing anything up.
I think on the ford,, I will do it old school. Maybe change it 2x if I am that concerened about contaminates or build up. It would still be cheaper thasn flushing the lexus.
Old Nov 28, 2006 | 05:45 PM
Aaron77's Avatar
Aaron77
So, to "flush" the system at home, you are draining through a line, and filling simultaneously? How do you gauge when your through the old, by color? Or maybe by volume?
Old Nov 28, 2006 | 05:57 PM
L8RG8R's Avatar
L8RG8R
I had a bad "flush" experience with my Expedition so I'll be sticking with the traditional drain and change.
Old Nov 29, 2006 | 07:09 AM
Casey's Avatar
Casey
Here's the procedure:
CLICK HERE
Old Nov 29, 2006 | 05:47 PM
Jetfixr's Avatar
Jetfixr
I change all my fluid every 30k using the cooler line method. Preventative maintenance is the way to go. "If it aint broke don't fix it" does not apply to expensive vehicle drivetrains
