Heater Assembly
Old Feb 25, 2005 | 12:18 PM
djshoser's Avatar
djshoser
Smile New Heater
I have a 1965 Ford F100, and my heater works, but I agree with you that it is not very efficient. I was looking for a heater for my 63 Falcon Hot Rod, and came up with this unit. I know a guy who installed one in his Falcon and loves it.
<TABLE cellPadding=7 width="100%"><TBODY><TR><TD colSpan=2>Heating and Cooling : Heaters</TD></TR><TR><TD colSpan=2 height=20></TD></TR><TR><TD vAlign=top width=200></TD><TD vAlign=top align=left>Hi Performance Air Hot Rod Heater
MANU: Southern Air
SKU: 842H
<SMALL>Hi Performance Hot Rod Water Heater. Can hookup to Defrost or Louvers. Only 8\ wide, 7\ deep, 3\ high.</SMALL>
<SMALL>Price: $ 109.00</SMALL>
</TD></TR></TBODY></TABLE>
This is from Southern Rods and parts on the web
Good luck!
Dave
Old Feb 25, 2005 | 01:58 PM
camperspecial65's Avatar
camperspecial65
Toque...banjo nailed it on the head as to the description of the heaters and differences....another thing which makes things drafty in 65-6 is the side vents....foam used there too on inside of door and as with heater is all but gone....
Banjo.....superb description....you shoulda been the autor of that part in the books hehe....I have seen a couple of the valves ya gotta shut off under the hood....looks like a pain unless you got a crescent wrench....
-cs65
Old Feb 25, 2005 | 03:05 PM
garbz2's Avatar
garbz2
61 to 64 interchange between F100 through F350 2 wheel drive and four wheel drive. either Delux or standard. Delux used a fabric duct and oval mount on the passenger kick panel for fresh air replacing the passenger lever vent.
65 F100 F250 F350 and 66 F250 F350 four wheel drives and F350 2 wheel drives share a common box with variations.The backing plate mounts with four bolts to the old style flat firewall but still utilizes the new style front housing and connection to the round kick panel opening. These have a core all to them selves. but a short pipe 65 66 can be used with some extensions soldered on. Typically there will be the old style vent and pull on the drivers side and the new style v shaped vent with the round duct connection on the passengers.
65 66 f100 f250 two wheel drive and 66 F100 four wheel drive interchange. the firewall on these truck had a stamped area protruding into the engine compartment to fit the assembly.
Also note that the heater core till 72 is a replacment for 65 66.
I ran into the oddball things when i rebuilt a heater box for my 66 crew as it had a box that did not match up to any of the 61 through 66 boxes i had in stock. The cab i have was a canuck built 66 F250 4x4. The core is longer in the inlet piping and the heater box is made up of both 61 thru 64 and 65 66 parts.... a real conglomeration.
Garbz
DR Smith
31
Oct 20, 2017 09:32 AM
harleymsn
Jan 6, 2017 10:06 PM
treverd
Mar 30, 2016 09:31 PM
CSmalley64
Nov 18, 2015 08:06 AM
Conserv
Jan 17, 2014 12:40 PM
