Sponsored by: Kumho
Anti-locks ... LOCK
Old Feb 23, 2005 | 01:30 AM
Teancum's Avatar
Teancum
Anti-locks ... LOCK
When it is cold, as I go to work in the morning, the front breaks on my '89 F-150 are VERY touchy and lock up quite easily. Any ideas why? When the truck has been driven for a while, say 10-15 minutes, everything is fine.
Thanks for you time
Old Feb 24, 2005 | 01:16 AM
Hypoid's Avatar
Hypoid
I'm surprised no one has responded. I don't know much about anti-locks, but I'll start with a few of the simple things to ponder:
"when it's cold"; Good observation on your part, how cold?
When was the brake system last flushed and new fluid installed? Brake fluid is alcohol based, it'll suck moisture from the air. That's how you get water (and corrosion) in the brake system.
Does the ABS look original to the truck? If it is... Cripes! It's old enough to join the Army.
Good luck, Mike
Old Feb 24, 2005 | 01:36 AM
aurgathor's Avatar
aurgathor
On what surface and at what speed do you drive when those "lock-ups" can happen?
K trout
1997 - 2003 F150
May 12, 2014 02:29 PM
jo15765
Sep 6, 2013 10:15 PM
crazer42
Mar 1, 2009 09:41 PM
max1242
Mar 4, 2007 12:26 PM
justwufn
Jul 29, 2002 06:05 PM
