1966 - 1977 Early Broncos
Heater Hose Problem
Old Feb 22, 2005 | 11:02 PM
77 Bronco's Avatar
77 Bronco
Heater Hose Problem
I was putting some finishing touches on the engine bay off my 77 the other day and started to hook up the heater hoses to the heater core......and found that when I put on the hose it gets kind of kinked.....just a lil....because of the inner fender well and I am worried that it will restrict the flow. When I started the project it had the original style hoses on it....molded to turn and go to the water pump and heater control valve. Since I am replacing all the hoses as a precaution....I am looking for some molded heater hoses or maybe another solution. Does anyone have a suggestion?
Old Feb 23, 2005 | 12:52 AM
iggy1982's Avatar
iggy1982
Wink
mine does the same, so does every one i have ever seen. i would not worry about it, flow will be fine.
Old Feb 23, 2005 | 11:32 AM
oh2bnok's Avatar
oh2bnok
You can splice in that small water inlet hose , the one on the upper radiator hose neck.
Old Feb 23, 2005 | 03:23 PM
76 MA Bronco's Avatar
76 MA Bronco
You can also get a thin wire spring, the I.D. being the O.D. of the heater hose, the spring will prevent the hose from kinking.
It's how I bend 1/2" oil line to put heat in my garage, works like a charm.
Old Feb 23, 2005 | 06:02 PM
popsbronco's Avatar
popsbronco
heater hose prob
i likes the last suggestion about the small spring 76 ma bronco .
good idea as i wanted to change my hoses also.
they kinked so i put the original hose back on .
I will be trying the spring idea soon
Thanks man!
Old Feb 26, 2005 | 10:27 PM
italianrich's Avatar
italianrich
ive run straight hose for years through 103 and -30, never have had an issue with it kinking it closed. I like the wire inside idea too, might try that .
Rich
Old Feb 28, 2005 | 11:39 AM
68 351 bronc's Avatar
68 351 bronc
Good auto parts stores like NAPA or CarQuest have hoses with a 90 degree bend on one end in a variety of lengths. I have tall aluminum valve covers on my 351 so I had to route the hose to the control valve along the firewall and behind the valvecover. By joining two pieces with a brass conector and hoseclamps so I had 90s at both ends of a 12inch long piece it made for a very clean instalation.
I will try to get a pic on here tonight.
Old Feb 28, 2005 | 03:04 PM
77 Bronco's Avatar
77 Bronco
Great!....
I hope to see a pic of that soon....thanks And thanks to everyone for your ideas.
diesel 04 X
Dec 1, 2024 10:24 PM
rcraft
Mar 30, 2014 03:55 PM
jamesmcowan
Feb 3, 2010 12:37 PM
sidwaz
Jan 20, 2009 10:03 PM
andy_547
Sep 14, 2008 04:27 AM
