1978 - 1996 Big Bronco
Erratic Speedometer
Old Feb 22, 2005 | 08:52 PM
z01tde's Avatar
z01tde
Erratic Speedometer
i have a 95 Bronco with a 5.8 engine & electronic O.D. trans(I'm not sure which one it is but it's the push button in the shifter column). My speedometer works fine aat slow speeds up to about 45 mph but when I go higher it starts to swing & jump around. There's no way to use the cruise & I'm never sure what my speed is. Any suggestions?
Old Feb 23, 2005 | 01:27 AM
greystreak92's Avatar
greystreak92
First stop would be the top of the rear differential housing. You will find the VSS (Vehicle Speed Sensor) there held in by a single bolt. After making certain that the connection to it is reasonably sound, remove it from the diff. housing and give it a good cleaning. Reinstall and see what you get. If the problem persists, try changing the differential oil. (This sometimes washes away any crud that may be built up on the trigger ring in the diff). Worst case scenario, you will need to replace the VSS.
Old Feb 23, 2005 | 06:05 AM
Freakazoid!'s Avatar
Freakazoid!
When you drain the gear oil, be sure to inspect the differential itself. I had the same problem about a year and a half ago. It turned out that the differential carrier had cracked on one side and chewed up the spider gears. I wish you better luck than that!
Old Feb 23, 2005 | 06:15 PM
z01tde's Avatar
z01tde
Thanks for the info, I'll check the rear diff as soon as I get a day off.
Old Feb 24, 2005 | 10:12 AM
Kemicalburns's Avatar
Kemicalburns
also if you have an ls in the rear be sure to get that special ls gear lube for it along with the proper rear end stuff. it comes in a tube.
later
Old Feb 24, 2005 | 10:48 AM
OfficerLow's Avatar
OfficerLow
I also had a 95 EB Bronco 5.8 automatic that did the same thing. The dealer ended up replacing the speedometer. Luckily it was covered under the extended warranty. I can't remember what the mileage was when that happened. I want to say between 50000 and 60000
Old Mar 1, 2005 | 02:43 PM
Broncobirdy's Avatar
Broncobirdy
later
Friction modifier? I think its 4 ozs. Not sure I picked up 2 tubes for my diff. oil swap whenever I get time.
Zachthemoo2
Oct 2, 2014 04:42 PM
smokeywagon
Sep 4, 2014 09:20 PM
cracked lp
Jun 18, 2009 10:57 AM
Ford Freak
1997 - 2003 F150
Mar 31, 2004 08:24 AM
AdamH
1983 - 2012 Ranger & B-Series
Mar 28, 2002 10:23 PM
