Speedometer gear
Old Oct 1, 2014 | 01:26 PM
Zachthemoo2's Avatar
Zachthemoo2
Speedometer gear
My 77 f250 has a set of 37" Toyo m/t's on it and the speedo is off at higher speeds. I was wondering if I got my speedometer re geared if it will fix this problem.
Old Oct 1, 2014 | 02:16 PM
OverReved's Avatar
OverReved
That will fix your problem. Most cities will have a shop that does recalibration. Check a few driveline shops.
Old Oct 1, 2014 | 08:36 PM
Fordworth's Avatar
Fordworth
No need to waste your time with a shop. You just need to change the driven gear on the end of your speedo cable where it installs in the trans. It takes about a minute and a half and you can buy the gear for about $15. A gear with less teeth will drive the speedo faster which is what you need with taller tires.
Old Oct 1, 2014 | 08:58 PM
Fordworth's Avatar
Fordworth
I've used this calculator to select the right gear. Remember,you're looking for the driven gear. Leave the speedo revs per mile at 1000 and enter 7 for the drive gear teeth. You also need to know your rear gear ratio. The result will tell you which driven gear you need.
http://www.wallaceracing.com/speedo-calculator.php
Here's what the gear should look like. Make sure to get one with the proper tooth pitch. There are both right and left handed versions but they are marked as in the photo.
<a href="http://s742.photobucket.com/user/Fordworth/media/Seedo%20gears/2013-01-02_19-50-47_578_zps5ab65cdb.jpg.html" target="_blank"><img src="http://i742.photobucket.com/albums/xx65/Fordworth/Seedo%20gears/2013-01-02_19-50-47_578_zps5ab65cdb.jpg" border="0" alt=" photo 2013-01-02_19-50-47_578_zps5ab65cdb.jpg"/></a>
Old Oct 2, 2014 | 12:57 PM
Zachthemoo2
So I just used the calculator and it says I need 15 gears, does that sound right to you
Old Oct 2, 2014 | 01:21 PM
Fordworth's Avatar
Fordworth
That very well may be right. However, they only come with as few as a 16 tooth count.
Old Oct 2, 2014 | 01:24 PM
Fordworth's Avatar
Fordworth
What is your rear gear ratio?
Old Oct 2, 2014 | 02:13 PM
Zachthemoo2
The tag on the diff says 4:10's
Old Oct 2, 2014 | 04:42 PM
lafermedavid's Avatar
lafermedavid
Bronco graveyard has them
PetesPonies
Jun 2, 2010 11:04 PM
jas88
Jun 24, 2007 05:42 PM
'88_F-150
Nov 2, 2006 09:27 PM
yellow72f100
Nov 2, 2005 06:52 PM
