there is a tag on the rear housing for the rear end the bottom number like 4:17 should tell what ratio it is... I would imagine it is 4:15 to 4:55 usally 4x4's are geared real low
First jack up one side at the REAR of the truck ,make a chaulk mark on the tire and a corresponding mark on the ground/driveway/garage floor.
If the tire won't turn freely >you have a locking rear end which means ,you now jack up the other side too.
Now align the tire mark to the ground mark >
While turning the tire ONE revolution >Count the number of times the driveshaft turns >
If the DriveShaft turns 3 1/2 turns to One revolution of the tire >
You have a 3.50:1 rear > If it turns Just around 4 times >chances are you have a 4.10:1 rear
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
They are usually the same AFAIK.
The tags >
They are so important especially if the Door is the original and the tag hasn't been removed.
Dennis
