Front brake is sticking
Old Feb 20, 2005 | 08:14 PM
nuts4hotwheels's Avatar
nuts4hotwheels
Question Front brake is sticking
I have a 1988 Clubwagon and one of the front brakes keeps sticking. It happens when you press the brake, it doesn't fully release. You can hear it rubbing against the rotor. Usually if I tap the brakes it will release again. Does anybody what could be causing this? I made sure to grease where the pads slide on the rotor assembly, but it didn't help?
Old Feb 20, 2005 | 09:25 PM
94van's Avatar
94van
It's probably the caliper sticking, like mine did once. Probably just go get a replacement one and install it.
Old Feb 20, 2005 | 09:50 PM
Wiskey6's Avatar
Wiskey6
I agree that the caliper could be bad.
I had a Dodge van that had sticking calipers and I was about to R&R the calipers, and found that the shaft that the brake pedal arm was mounted on, was rusted up because it had sat for a long period of time.
It was a real pain just to get the rod/bolt out, but once I did, I lubed it up and reinstalled it. No more problem.
Old Feb 21, 2005 | 02:31 PM
85e150's Avatar
85e150
My RF caliper stuck and you could have baked bread in the vicinity of the RF wheel after a short drive.
According to my excellent little old brake shop, the pistons in my '85 E150 were plastic. If you have a 150, you probably have the same quality units.
They rebuilt the calipers with proper steel pistons.
I suggest you do the same.
Both sides now, don't cheap out.
Old Feb 21, 2005 | 05:16 PM
haroldservice's Avatar
haroldservice
another reason for brakes to "stick" is a bad hose, the interoir of the hose collapses and the fluid under pressure gets in but cannot get out. i lost a rotor to this. now i go with really high quality hoses, cheaper than rotors.
alchemist1
Mar 17, 2014 08:54 PM
bismic
Mar 23, 2012 03:27 AM
mich800
Nov 5, 2010 10:24 AM
jfarcas
21
Mar 11, 2008 07:18 PM
eagle6386
Jul 13, 2003 12:03 PM
