steering column
Old Feb 20, 2005 | 04:32 PM
ford-nut's Avatar
ford-nut
steering column
I have a 78' f-150, 2wd, auto, with column shift.
I located a tilt column from a 79 bronco 4x4 with column shift.
Can i swap this column into my truck?
Old Feb 20, 2005 | 04:55 PM
Mil1ion's Avatar
Mil1ion
Yep !
Straight swap with the 4x4 shaft removed.
Just put the metal flange from the 2x4 on the 4x4 column as the splined end of the columns are the same
Old Feb 20, 2005 | 05:05 PM
oldhalftons's Avatar
oldhalftons
it depends if the 78 has a splined or welded end.
Old Feb 20, 2005 | 07:56 PM
ford-nut's Avatar
ford-nut
thank you
Thanks guys for the reply, I will have to look and see if mine is welded or splined. Either way i do apprieciate the info. This site is great..
Old Feb 20, 2005 | 08:02 PM
Mil1ion's Avatar
Mil1ion
I take back what I said,after re-reading I thought having TILT was mentioned but wasn't.
Sorry for any problems I caused
Old Feb 20, 2005 | 08:16 PM
4x4pete's Avatar
4x4pete
you need a 4x4 coulmn 78 or79. or you could make it fit but the right coulmns are plentiful
Old Feb 24, 2005 | 01:21 PM
GeneStoner's Avatar
GeneStoner
Both columns are power steering, right?
Old Feb 24, 2005 | 02:51 PM
hawkrod's Avatar
hawkrod
Boy, this got confusing quickly! LOL yes, a 4X4 tilt steering column will fit a 2 wheel drive. They are the same column. What you will need however is the coupler that a 2 wheel drive used that a 4X4 didn't. Many 78/9 non tilts had this same coupler. If your old column doesn't have a removable coupler (splines on both sides) you will need to find one but they are readily available and also fit ford vans with tilt. This coupler is actually the same a regular 2 wheel drive coupler but has an extra piece on top with splines to attach to the column. Like I mentioned, many 78/9 non tilt 2 wheel drive columns already have these but not all as some have a welded on flange. Earlier trucks all had a welded on flange but for some reason ford changed it as time went on. Hawkrod
Old Feb 25, 2005 | 07:35 PM
ford-nut's Avatar
ford-nut
steering column
Thanks for the info. I took mine out and my coupler was not welded. I am going to swap these since i like the tilt better. THANKS FOR THE GREAT INFO!
Sep 26, 2023 02:47 PM
T_Cooksey88
Mar 17, 2016 11:23 AM
tacson
Jul 5, 2008 03:31 PM
dfwdiesel
Dec 13, 2007 09:08 PM
black89
Dec 29, 2006 08:40 AM
