Oil pressure drops at temp and speed...
Can someone enlighten me...
When my truck is cold and idling, the oil pressure is midway on the stock (72 F250, 390) guage. When it warms up and/or when I go faster the indicator drops.
When I'm on the freeway, warmed up and doing 75, the indicator drops down to the bottom (oil pressure is LOW) of the scale.
The truck seems to run fine all the time. The oil looks good through it's life span, and it gets changed every 3k since I've owned the truck.
Oil is 10-W40.
I would have thought... higher RPM's... would equal faster oil pump rotation... would equal higher oil pressure.
If anyone has any thoughts, I'd appreciate hearing them.
Thanks.
Oil is 10-W40.
Thanks.
Thanks guys...
I'll get a mechnical guage. Do I screw that into where the sending unit is screwed in presently?
It doesn't make any noise when the guage indicates "Low". It just purrs along.
Maybe I should just replace the sending unit. I imagine they are somewhat cheap.
The guage is OK, because I can ground the lead off the sender and the guage deflects full scale.
Thanks again for the ideas.
samckernan
samckernan
Finmad
07-06-2016 06:44 PM
TallPaul
Oil & Lubrication
18
09-10-2003 07:26 PM
