1966 - 1977 Early Broncos
Transfer Case.....
Old Feb 20, 2005 | 11:46 AM
77 Bronco's Avatar
77 Bronco
Transfer Case.....
Hello, I have a 1977 Bronco that I have been completely going through the drive train on. I had the transmission rebuilt along with the transfer case and I am curious as to what type of lube goes into the tranfer case. The original truck manual says: Above 10 degrees F -- SAE-50 and Below 10 degrees F -- SAE-30. I've talked to two guys and was told to use a motor oil. I just kinda looked at them funny ... The fluid that came out of it smelt like rear end fluid or gear lube. I figured I would ask on here since there are alot more inteligent people on here then at my local parts store. If someone could help me in my cituation it would be greatly appreciated.
Old Feb 20, 2005 | 02:47 PM
RCrawler's Avatar
RCrawler
The transfer case uses 80w-90 gear oil. Ford recommended 50 wt in some transmissions for easier shifting in cold climates. But I've always used regular gear oil and haven't had a problem down to -20*F.
Jason
Old Feb 20, 2005 | 06:12 PM
popsbronco's Avatar
popsbronco
transfer case
Jason
Though i'm not doubting Rcrawlers knowledge.
I read in my ford manuel for my 1977 bronco that you use 10w 30 and or 5w30 motor oil why is this and i would have thought that for would recommend gear oil 80w 90
Right know iam using 10w 30 syn motor oil
Should i change it to a synthetic gear oil instead.
What the info in the ford manuel the wrong info??
Old Feb 20, 2005 | 09:14 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I've always used gear oil in my Bronco's Dana 20 t-case without problems. Last time I changed it I put in 85/145 Valvoline.
Old Feb 20, 2005 | 09:59 PM
RCrawler's Avatar
RCrawler
Yes, that is what they recommend. 30w for cold climates and 50w for warm climates. The cutoff is 10*F average. I have found that the 30w is too thin for most applications unless you are changing fluids every 6 months when the weather changes. FWIW, there is a difference between 30w- 50w engine oil and transmission oil. If you want to run synthetic, I would recommend Unocal 76 Syn Lube CD-50. We run it in some of our log trucks with a drain interval of 500,000 miles. Very good quality but a little expensive.
Jason
Old Feb 23, 2005 | 06:07 PM
popsbronco's Avatar
popsbronco
manuel says oil in trans case??
52F1Gary
Feb 17, 2015 12:05 PM
rwkinch
Dec 23, 2012 03:23 PM
Marauder2004
May 31, 2010 07:34 AM
piersol
Dec 25, 2009 09:49 AM
21411
Aug 5, 2008 08:25 PM
