1978 - 1996 Big Bronco
Can't get a spark plug out
Old Feb 19, 2005 | 08:03 PM
YankeeFan's Avatar
YankeeFan
Cool Can't get a spark plug out
I can get the plug socket and ratchet with wobble joint on it but can't get the leverage needed to turn it. It's the plug on the passenger side against the firewall. Any tips or tricks you can give me to help out?
Old Feb 19, 2005 | 10:40 PM
DcSkater602's Avatar
DcSkater602
run the motor for a minute...the heat will help it come loose easier...i never had a problem getting mine out
Old Feb 22, 2005 | 07:10 AM
RichardMaerz69's Avatar
RichardMaerz69
do like DcSkater602 said,but spray some penatraiting lube on the plug,the heat from the motor will suck the lube into the threds and help loosen the plug.If you can just use a normal plug socket on it,if the wobble joint slips youll break the plug,you just about have to climb up into engine compartment to get leverage on it.
Old Feb 22, 2005 | 11:15 AM
JBronco's Avatar
JBronco
That one is a little harder then the rest. If I recall, I used a reguler ratchet and socket without a wobble joint on it and got it out pretty easily. I also use a stepstool so I can get up there and into the engine compartment better.
Old Feb 22, 2005 | 02:16 PM
BillyBob69's Avatar
BillyBob69
JBronco method works for me but without a step stool I always keep a 5 gallon bucket to stand on. I have also wound up using 2 u-joints with 1 long extension and 1 med extention on a 3/8 ratchet.
Old Feb 22, 2005 | 02:34 PM
JBronco's Avatar
JBronco
I used to use one of those white plastic chairs - I got tired of the chair slipping on the driveway while I was working and causing me to bust a knuckle or a kneecap or something. It f'in hurts and you look like a fool too, when it happens. Five gallon plastic buckets do the same thing, I know by experience because I have used them too.
For safety's sake, use something with a rubber base that won't slide. I now use a cheap stepladder with rubber feet.
Old Feb 22, 2005 | 03:22 PM
BillyBob69's Avatar
BillyBob69
What? no risk? Awwww cmon!!!!!! What fun would it be if we didnt risk a few knuckles, knees or elbows when working on our beasts? Get a chair with wheels!!!!
JUST DO IT!
Old Feb 22, 2005 | 04:30 PM
poffutt's Avatar
poffutt
I got mine out with a regular ratchet with about a 2-3" extention, then I put a box-end wrench (long 1") on the ratchet handle to give lots of leverage. Or use a cheeter pipe.
Old Feb 22, 2005 | 04:46 PM
JBronco's Avatar
JBronco
JUST DO IT!
I'm getting too old for that! What used to stop hurting the same day, now hurts for a week!
And have you ever had it happen, anyway? You are standing on your bucket or whatever, and struggling to get the spark plug out and then the bucket slips out from under you, and your legs are flailing around in the air looking for some solid ground while the back of your head hits the hood, leaving a nice bump, and your hands slip off of whatever they were on and scrape across the engine leaving bloody scratches all over your hands and arms that you have to explain for the rest of the week? And you don't wanna tell them what really happened!
Old Feb 23, 2005 | 08:41 AM
BillyBob69's Avatar
BillyBob69
Yea I been there...kinda the two times it has happened, I have been lucky that both times my belt buckle caught me so I was flailing my legs but not falling. Hmmmmm Gravity sucks! But I have cracked, scratched, and cut my hands and arms many times....Oh and burned em too. I did see once tho, I cant remember what they are called, but it is a system of platforms that you can set up around your vehicle to help get under the hood of the larger vehicles. Anyone know what they are? They had em on TRUCKS.
Old Feb 23, 2005 | 02:11 PM
jacque_strap's Avatar
jacque_strap
Just an idea, although I've never tried it, but how about those step that attach to the wheel, like RV's or campers have to reach the roof rack. It would only be good for the side but might still be worth it.
Mikeyg76
2009 - 2014 F150
Jun 3, 2016 12:09 AM
OBSGuy45
Apr 5, 2016 12:00 AM
Dodgeyaussie
1997 - 2003 F150
Apr 19, 2012 10:05 PM
grantorino
19
Apr 22, 2007 03:08 PM
TallPaul
Jul 8, 2004 11:57 PM
