Flywheel removal?
Old Feb 19, 2005 | 11:06 AM
RawPower's Avatar
RawPower
Flywheel removal?
How do you get the flywheel off? I have the clutch pad/plate off, and now its just the flywheel with no bolts. How does it come off?
Does the starter need to come off with it?
Old Feb 19, 2005 | 11:32 AM
PLC7.3's Avatar
PLC7.3
If you have it just sitting there with no bolts in it be careful, I believe it is only supported by a very small shoulder now. The DMFs are heavy so get help.
Old Feb 19, 2005 | 11:36 AM
RawPower's Avatar
RawPower
DMF's?
It feels like its on there pretty good, do you think it could be rusted on there?
Also, how thick are clutch pads supposed to be? (93 ZF 5spd)
Old Feb 19, 2005 | 02:30 PM
RawPower's Avatar
RawPower
OK, thanks. It came off. There is a 1/8 lip thing that was holding it on. It was rusted to it.
The fly wheel wasnt too heavy, about 30 lbs., but I took it and the clutch assembly apart as much as possible before taking the flywheel off.
Only the block mounts, oil pump, pistons and camshaft remain...
ssg1957
Jan 27, 2015 08:48 PM
Hsbrder01
Aug 21, 2011 05:29 PM
Mattb6679
Apr 19, 2009 08:10 PM
yard_dawg
Sep 28, 2008 01:27 PM
mh822
Jul 9, 2006 02:04 PM
