302/351 same flywheel?
Old Apr 22, 2006 | 09:04 PM
mh822's Avatar
mh822
i have a '68 302. i know i need a 164 tooth 28oz imbalance flywheel. does it have to come off of a 302 or can it come off a 351? also will the alternator brackets off of a '84 351 fit my '68 302? how 'bout the distributor. i'd like to upgrade to electronic ignition. thanks
Old Apr 22, 2006 | 09:21 PM
fordxxx's Avatar
fordxxx
I used a 164 teeth 351 flywheel in my '72 302 and it worked fine. It was out of a mid 80's F-150.
Old Apr 23, 2006 | 06:07 AM
ken75ranger's Avatar
ken75ranger
He's right. The flywheel will work. Distributor no. Alternator doubtful. If it's the kind that bolts to the head and the block no, the deck height is different.
Old Apr 23, 2006 | 12:57 PM
mh822's Avatar
mh822
thank you that widens my search.
Old Jul 5, 2006 | 05:14 PM
henritrinelli's Avatar
henritrinelli
Ignition fire order for 302 is different than 351 , so de distributor won´t work.
Old Jul 5, 2006 | 08:04 PM
baddad457's Avatar
baddad457
Some 351 brackets fit 302's too. Ford used both types on both blocks using an adapter bracket that bolted to the head. You got a 50/50 chance there.
Old Jul 9, 2006 | 02:04 PM
kenz28's Avatar
kenz28
The distributor will not work because of the physical size differences in the to different distributors -
1- the 351 distributo is a little longer
2- the oil pump drive shaft is bigger on the 351.
Hope this helps.
KenZ28
arctic y block
35
Aug 4, 2007 09:59 PM
70blue
Apr 13, 2007 05:43 AM
oldmansimek
Mar 11, 2007 03:34 AM
FordPickup460
Jul 12, 2004 03:14 PM
