Sponsored by: Auxito
need help
Old Feb 19, 2005 | 09:48 AM
guillermogodinez's Avatar
guillermogodinez
Angry need help
i have a 97 ford f-150 lariatxlt and having trouble taking it out of park and no break lights i have changed the switch up on the pedal but still nothing for me to get it out of park i need to go up under the sterring column and flick a switch up there please need help
Old Feb 19, 2005 | 10:44 AM
LxMan1's Avatar
LxMan1
Welome.
Have you checked the fuses? Is there 12V going to one side of the switch?
I have read of broken wires going to the switch too.
Old Feb 19, 2005 | 03:35 PM
guillermogodinez
the fuses are good and their is no wires that seem to go to the brake pedal switch, i believe its has something to do with the relay up in the steering column please help
Old Feb 19, 2005 | 03:41 PM
stepman's Avatar
stepman
I believe you have a bad "lock" which locks it in park until you have your foot on the brake. A way to "get around it" would be to....turn the key but not all the way to "run", then shift it out of park (like to neutral) then start it up and see what happens. You should be able to shift gears once it is out of park.
Old Feb 23, 2005 | 11:09 PM
billsbigbronco's Avatar
billsbigbronco
i know this sounds strange but check brakelamp bulbs first.
boulderbronco
6.4L Power Stroke Diesel
Oct 16, 2008 10:00 PM
speed
Electrical Systems/Wiring
Jul 16, 2006 01:20 PM
Beastmaster
Jan 24, 2006 12:13 PM
nitti62
1997 - 2003 F150
Aug 12, 2004 06:04 PM
deano512
Apr 1, 2003 02:58 PM
