Mechanical? or vacuum secondaries?
Old Feb 19, 2005 | 12:04 AM
deisele75's Avatar
deisele75
Which is better mechanical or vacuum secondaries
1978 F250 Supercab
460/C6
4X4
33X12.50
4.10
Old Feb 19, 2005 | 10:39 AM
LxMan1's Avatar
LxMan1
It really depends on the application.
There are a couple of different set-ups of mechanical secondaries.
There is the Holley type that uses dual accelerator pumps (double pumper) and there is the mechanical type with a secondary air flap such as Edelbrock (AFB/AVS) q-jet and the Motorcraft 4100/4300 series.
For a heavy vehicle with an auto tranny, all but the double pumper will work fine.
A double pumper is recommended for a light vehicle with a high stall converter or a manual tranny.
What are you wanting to change the carb on?
Old Feb 19, 2005 | 03:15 PM
FERacing66's Avatar
FERacing66
Unless your building a drag engine, get the vacum secondarys, ive heard of nothing but trouble with the double pumpers. Double pumpers are for race engines, they dont work good on street vechiles.
Old Feb 20, 2005 | 10:12 AM
deisele75's Avatar
deisele75
1978 F250 Supercab
4x4/460/C6
Old Feb 20, 2005 | 11:22 AM
LxMan1's Avatar
LxMan1
I like the Edelbrock carb on my 460. I would go with a 600cfm. If you do a lot of off-roading though, the Holley truck avenger 670 would be better due to the floats are less apt to bounce around and cause fuel issues. For mostly street driving, the Edelbrock will give better low end throttle responce and gas mileage.
Old Feb 20, 2005 | 10:10 PM
deisele75's Avatar
deisele75
most of the driving i do is on the street, i will probably go with the edelbrock.
Old Feb 20, 2005 | 10:45 PM
LxMan1's Avatar
LxMan1
I think that you'll be quite happy with that choice.
Old Feb 21, 2005 | 09:14 AM
victorcharlie's Avatar
victorcharlie
For the street, vacuum secondaries.
Old Feb 22, 2005 | 05:28 PM
FORD352V8's Avatar
FORD352V8
Dont let people scare you into thinking that Holleys are not good for street trucks. Aint so, they work fine and give you more power then the edels. Both are excellent carbs though.
Old Feb 23, 2005 | 11:27 AM
frty7ford's Avatar
frty7ford
Vacume secondaries and a truck avenger carb
Old Feb 23, 2005 | 11:23 PM
LxMan1's Avatar
LxMan1
The Holleys will give you more peak power, but for everyday driving, the Edelbrocks are easier to tune and give better mileage and low end torque and throttle response. Yes, both are good carbs, just depends on the application.
68cabby
Dec 2, 2012 01:01 PM
68Ford4Life
20
Jan 18, 2012 04:26 PM
stegmst
Apr 7, 2005 10:05 PM
barca_texas
Mar 22, 2005 05:45 AM
scottie2hottie
Nov 4, 2004 07:25 PM
