'79 3peed
Old Feb 18, 2005 | 06:33 PM
yaki69's Avatar
yaki69
Question '79 3peed
hey i just bought a '79 f100 a few months ago, and would like to know what the shift rpm's are on it. i dont have a tach so i dont know. also what is the rev limiter set to?
Old Feb 19, 2005 | 06:48 AM
BigBlue88's Avatar
BigBlue88
There is no rev limiter, but you're gonna run out of steam at about 3500-4000RPM. You'll feel it in the seat of your pants. You're in no danger of hurting the motor at those RPM, unless something is really wrong with it (which I doubt). What's your rear end ratio and tire size? Is this the 3-speed column shift?
Old Feb 21, 2005 | 11:32 AM
yaki69's Avatar
yaki69
my rear end ratio is a 3.42, and im running sum 225/45R15's . and yes it is a column shift. ive heard that overrevving can blow a rod, but im guessin thats only severe revving...
Old Feb 21, 2005 | 03:18 PM
BigBlue88's Avatar
BigBlue88
I don't have the exact ratios for your 3.03 tranny, but 3.03, 1.79, 1.00 oughta be about right.
You're gonna want to shift at about 18mph and 30mph for normal driving conditions. That puts your RPM's in the 1500-2500 range. You really don't want to go much lower than about 1500 for daily driving. Shift later when carrying loads, going uphill, or having fun.
Max MPH in each gear (assuming 4000RPM rev limit):
1st 25mph
2nd 45mph
3rd 80mph
If all you do is putt around town, you're OK, but with any sort of speed, you're going to rev the snot out of the engine. A 3.08 rear with your 3 speed is a classic combination, gets good mileage (20mpg on a good truck), runs well on the highway , and is well suited to the torque band of the 300ci six. Or you could go with larger diameter tires. But you have a low-speed truck right now. I'd recommend swapping the rear-end gear to a 3.08. $200 in parts, and a garage or a friend oughta do it easily.
Old Feb 21, 2005 | 06:30 PM
yaki69's Avatar
yaki69
alrighty thanx. since me havin a 3.42, you say go to a 3.08. isnt the higher the last number, the higher top end you'll have? im not sure if im correct on this one. i was thinkin about runnin 3.55's. i mostly use it to drive around town, but i like to have fun at the red lgihts, so...any ideas?...
Old Feb 22, 2005 | 07:05 PM
BigBlue88's Avatar
BigBlue88
Nope, other way around. Gear ratios are #input turns to #output turns. So your driveshaft turns 3.42 revs for every 1 rev of the rear axle. 3.55's would make you rev higher to turn the same axle speed.
The 300 doesn't like to rev (unless you do lots of work on it); it does best doing torquey-things, and you're revving the snot out of it on the highway. You'd find the truck would be quite happy with a 3.08 (I think); smooth acceleration with less frequent shifting.
You'll get much better performance gains by doing the standard carbed 300 upgrades- EFI exhaust manifolds (or headers), Offenhauser or Clifford dual-plane intake and a 390-450CFM carburetor. Search the Inline board; there's TONS of information about the aforementioned upgrades.
But that all depends on how much you want to spend on this truck.
Old Feb 22, 2005 | 08:17 PM
yaki69's Avatar
yaki69
alrighty, well i was told wrong then about the gear ratio. thanks for clearin that up for me. all i have done to it is a brand new 1barrel carb, and open straight pipes, no cats, no mufflers, nada. so...i was thinkin about the offensauser (3) 1 bl. carb set up, but dunno about the power output, plus keepin all three tuned would be a pain, but..any suggestions would help..
Old Feb 22, 2005 | 08:36 PM
BigBlue88's Avatar
BigBlue88
For drag racing, higher gears are often better, because you get better acceleration.
I bet your truck sounds awesome...
Most anything is better than the Ford YF carburetor. Carb, intake, headers/manifolds, and you'll grin from ear to ear.
Old Feb 23, 2005 | 04:30 PM
yaki69's Avatar
yaki69
yea its a eye catcher how loud it is. so the lower the gear, the less acceleration ill have but a more top end, and wiht higher gear faster accleration, but lower top end?right?
Old Feb 23, 2005 | 09:16 PM
BigBlue88's Avatar
BigBlue88
Yup. And with a top-end of 80mph, you're already at serious drag-race gearing. :-)
I wouldn't go with any higher gearing unless you're gonna swap in an overdrive transmission or put on large tires.
Old Feb 24, 2005 | 04:56 PM
yaki69's Avatar
yaki69
alrighty well thanx for the advice and correcting my understanding of gears. il keep you informed if i do any more to it.
1980Supercab
Feb 5, 2015 12:30 AM
joel79ford
Aug 16, 2011 06:21 PM
gbrett
1978 - 1996 Big Bronco
Jun 1, 2011 10:14 PM
vinlin95
Dec 7, 2007 12:02 PM
79Ford460
Ford vs The Competition
90
May 5, 2004 05:19 PM
