cleaning the engine
Old Feb 17, 2005 | 12:09 PM
lewisbest's Avatar
lewisbest
cleaning the engine
what is the best way to clean mud off of the engine?
Old Feb 17, 2005 | 12:50 PM
Champ's Avatar
Champ
Water? Check your owners manual I believe its page 222-223 that tells you what compnents to cover up and not get wet.
Old Feb 17, 2005 | 05:29 PM
TestPilot's Avatar
TestPilot
Lewis,
I've been hosing down my engines, both on my '01 and now on my '05, every time I wash my truck. I don't cover anything and haven't seen any ill effects, except for a saggy hood liner on the '01. Avoid the liner and you shouldn't have a problem.
Old Feb 17, 2005 | 05:36 PM
Johnnyboy04's Avatar
Johnnyboy04
Is there anything out there that will remove dried mud stains from my engine. I have tried that gunk engine cleaner and it doesnt seem to work.
Old Feb 17, 2005 | 05:46 PM
TestPilot's Avatar
TestPilot
In the engine compartment, I haven't seen anything that works better than dishwashing detergent and elbow grease.
Old Feb 17, 2005 | 08:04 PM
mjgrifall's Avatar
mjgrifall
I always use Simple Green. Wet the area first, then spray, wait a couple of minutes and hose it down. The engine will sparkle.
Old Feb 18, 2005 | 01:04 AM
ATCS2004's Avatar
ATCS2004
Don't know about the ill effect of Simple Green on your engine, but we quit using it on or around USN Jets because it caused corrosion and etched the windscreen and canopy's.
Old Feb 18, 2005 | 01:30 AM
kato14709's Avatar
kato14709
Thumbs up
What I've found that works great is Gunk's Foamy Engine Brite. With the engine warm, not hot, spray everything down under the hood. Let it sit a while then hose it off. I do this at a manual wand car wash. While your washing the rest of the vehicle, let the foamy brite do it's thing, then when it comes to rinse time, do under the hood. Use some common sense where not to rinse under high pressure. This will clean the engine and compartment up nice. For detailing it to look like new, mist some armor all or similar product all over the engine and compartment and be on your way. When you look under the hood again, you'd think a dealer or body shop just detailed it. Looks great. I've done this for years and it works great with no ill side affects.
turtlemann14
May 4, 2013 06:53 AM
tseng19
2004 - 2008 F150
Mar 27, 2012 07:33 AM
tr0y
Mar 2, 2008 10:49 AM
snoman
Appearance & Dress-Up
Oct 27, 2004 09:32 PM
TJF
Garage & Workshop
31
Mar 15, 2003 07:45 PM
