Sponsored by: Real Truck
Engine Bay Cleaning
Old Mar 1, 2008 | 10:46 AM
tr0y's Avatar
tr0y
Engine Bay Cleaning
Does anyone have any thoughts on the best way to clean the engine bay on the SD with a 6.0 Diesel.Not that it is filthy but a nice clean engine looks so good
Thanks
Old Mar 1, 2008 | 10:53 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I use simple green, I spray it all over the engine then use a water hose to spray it off. Be careful with the alt. and connections. Does a great job. After finish, crank to dry.
Old Mar 1, 2008 | 01:40 PM
Momorris's Avatar
Momorris
I'm too scraed to spray water all over these engines so I use a combination of break-kleen, foaming glass cleaner and a lot of rags. The break-kleen works on the oil, and the glass cleaner works well on dirt and coolant.
Old Mar 1, 2008 | 02:40 PM
3000 FPS's Avatar
3000 FPS
The owners manual shows pictures of the areas you should protect from water. I just use plastic bags and some duct tape and then degrease and hose it down. Looks great when completed.
Old Mar 1, 2008 | 08:30 PM
radio flyer's Avatar
radio flyer
make sure you wash it down when it is cold, then run to dry it. never put cold
water on hot engine.
Old Mar 1, 2008 | 08:36 PM
GT4point6's Avatar
GT4point6
Simple green works GREAT. Use the regular stuff, the autmotive stuff SUCKS. Not sure why but the original is best. I buy it by the gallon!
Cold engine, spray on, wait a couple of minutes, gently rinse. Don't use high pressure. Then I use an air compressor to blow most of the water off the engine as much as I can and I spray around the connectors to get most of the water off of them as well. Then start engine to dry it. I've used this on my BMW, focus, mustang, F250 and Miata without any problems. When your done, back up and look at all the dirt that came off your engine, amazing!
Kevin, 05 250 SD, XLT Sport V10, 4x2, 4.10, CC, Torqueshift towing the #63 CMC Mustang
Old Mar 1, 2008 | 09:10 PM
DumbEngineer's Avatar
DumbEngineer
I've always wondered what the used car dealers use... It must be simple (no manual labor) and it comes out looking nice... plastic, rubber all look even and shiney. Anybody know?
Old Mar 1, 2008 | 10:07 PM
BillyBob69's Avatar
BillyBob69
They use a spray on vinyl cleaner like for tires. The stuff you don't have to wipe off.
Old Mar 1, 2008 | 10:18 PM
ReAX's Avatar
ReAX
Here's the show car trick, Spray both windex (or generic glass cleaner) and Armoral (or better vinyl dressing) all over the hoses and engine. Then let the motor run for 15 minutes. It comes out great.
I go a little further with new dollar store toilet and tooth brushes. I use WD40 as my fluid to move the dirt. This approach keeps water way from the engine, but you still get it very clean.
Old Mar 1, 2008 | 10:44 PM
99whiteford's Avatar
99whiteford
I just put a garbage bag over my alternator,use simple green as mentioned and hose it down.I'll start it up and let it run until dry.after it has cooled down I spary everthing with armor all.makes it look almost new under hood.
Old Mar 2, 2008 | 07:57 AM
weyland426's Avatar
weyland426
A local detailer did my previous 5.4L and blew a coil pack. I had to have the Ford garage prove to the detailer that it was his fault by using excessive water/steam during the process...but could have been a fault in the coil casing as well. Long story short after a nearly $500 repair that I had to saddle...I use a different detailer and tell him to skip the engine.
Old Mar 2, 2008 | 10:49 AM
BobsF350's Avatar
BobsF350
ive been doing this for years and the truck has over 100,000 miles and i do it a few times a year.and no problems with the truck.
I buy the cheap degreaser from wal-mart its 1.17 a can i like it cuz it doesnt have a fuel smell to it like GUNK.i spray everything under the hood when its HOt and let it sit for a while till its cooled down then Hose it off and my motor is CLEAN.everyone who sees it always say how many miles on your truck WOW thats clean.
i usually use 2-3 cans
FordYoungGun35
Appearance & Dress-Up
Oct 18, 2013 11:45 AM
tseng19
2004 - 2008 F150
Mar 27, 2012 07:33 AM
mblanken881
Dec 17, 2011 08:35 AM
EXbowtieguy
Oct 25, 2011 11:16 AM
Cyanide96VR6
Bronco II
Oct 12, 2003 08:51 PM
