crossmember measurements
Old Mar 2, 2005 | 11:40 PM
bootie's Avatar
bootie
so you should be hee hee - my original question i was trying to get answered was the 48-52 cross member the same as the 42-47 - still unsure but figure they must be close - decided i can't be bothered with freighting a 48 crossmember from the states (which i'd need to convert to suit rh drive)so have decided to build one only getting all the info i need is a bit slow. like my truck low and slow
Old Mar 3, 2005 | 01:58 PM
Dodge41's Avatar
Dodge41
New pic is up in my Gallery of the crossmember. Remember though that these measurments are done in the field so they may have a small error in them but they are close. Hope this helps.
Old Mar 3, 2005 | 11:14 PM
bootie's Avatar
bootie
wicked thanx heaps
Old Mar 3, 2005 | 11:41 PM
bootie's Avatar
bootie
are we looking at the back of the crossmember or the front - basically which side is the m/cyl closer to the chassis on
cheers
Old Mar 4, 2005 | 07:54 PM
Dodge41's Avatar
Dodge41
The top picture is viewed if you were looking at crossmember from the front of the truck. ( passenger on your left, driver on your right ) the bottom picture is from the same angle but if you were looking down on the crossmember. While the measurments may not be right on I think they should help you get started, Good luck and hope this helps!
Old Mar 7, 2005 | 05:58 PM
uba40's Avatar
uba40
Bootie, I am new to this forum. I am not real hitech-ish. I posted a gallery to fte last night. After I posted it, I went in, found it, but could not access it to change it!! I looked all over the site including FAQ's and could not find answers. Could you kind of, send me a brief note telling me where to find the gallery stuff, can it be modified, etc.
Thank uba40
Old Mar 7, 2005 | 10:53 PM
bootie's Avatar
bootie
wrong person i haven't the foggest idea haven't had the time to set up a gallery - been planning to but way 2 busy managed to access your gallery sweet though - it seems to have all worked for you - just selected your name from above and view gallery
Old Mar 21, 2005 | 09:49 AM
46fordtruck's Avatar
46fordtruck
Bootie, know anybody in the states? There is an original crossmember on ebay right now, but the seller will only ship in the US. Check out item 4537397058
Old Mar 21, 2005 | 12:43 PM
bootie's Avatar
bootie
not really - prob just make something up
s-man56
Oct 28, 2012 09:37 PM
sdetweil
22
May 25, 2011 03:17 PM
halfdone
17
Nov 23, 2005 04:09 AM
paragary
Jul 13, 2004 02:47 AM
