Running rich??? help
Old Apr 15, 2005 | 11:07 AM
  #31
KST1's Avatar
KST1
Hey 77,
Did you ever figure it out? I'm having similar issues with running rich and was wondering what worked for you.
-D
Old Apr 15, 2005 | 01:20 PM
  #32
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Check your fuel pressure and codes.
Old Apr 15, 2005 | 02:29 PM
  #33
djd67's Avatar
djd67
i am also interested my 92 is doing the same thing but wont start. gave it 2 oilchanges in 2 days, oiled the cyl to get comp back up (with fuel relay removed) and instantly dumps fuel back into the oil. the entire fuel system has be replaced exept the injectors
Old Apr 15, 2005 | 03:11 PM
  #34
jlsahlen's Avatar
jlsahlen
check that EGR again, if that things stuck open it'll run like crap except if its supposed to be open (cruising speed). there should be no vacuum to it when youre idling
Old Apr 15, 2005 | 06:02 PM
  #35
77_F150_4x4's Avatar
77_F150_4x4
Yeah I ended up throwing another o2 in it and no more issues, after I moved my air tube from infront of the o2 to after the o2.
Curtis
Bartab
2009 - 2014 F150
Feb 8, 2017 06:01 PM
Bartab
2009 - 2014 F150
Feb 7, 2017 04:23 PM
Mark Everett
Oct 29, 2016 02:01 PM
6ohman2004
91
Aug 12, 2015 01:35 PM
BroncoBilt
1978 - 1996 Big Bronco
Jun 24, 2015 03:34 PM
