Anyone self install Cruise control?
The work involved to swap it is as follows;
disconnect the battery. Let it sit for at least five minutes.
pop out the two little discs on each side of the steering wheel, I used a sharp small screwdrive, after tapeing around where I was prying. Sometimes your hand slips...
remove the airbag retaining bolts. 8 mm socket, look back there with a mirror to see the angle they go in at.
remove the airbag, gently, of course. No static electricity, watch where you set it.
The air bag has a harness that has to be removed to pull the air bag, it has a red safty clip, push the red safty up with the small screwdriver, then press the connector to remove the harness.
Remove the connector for the horn.
Big torx 45-50 I forget socket holds the steering wheel in place. Note the wheel only goes on one way.
Use a hook type steering wheel puller. Cheap at most autoparts places, someone may lend you one, or you can rent them for a couple bucks many places.
Reverse the job to reinstall the new wheel, if you swap the wheel complete. If you want to keep your wheel you can remove the dummy buttons on your wheel and install the real buttons. Four screws.
Then drive to dealership and have them turn it on. If they don't know how, there is a hotline for the service techs.
Hope this helps, if you have any questions about the way things hook up or whatever, just ask.
P.S. I have a spare black wheel with the dummy buttons, a complete gray wheel with black buttons, laying here in my computer room.
Wanna buy a cruise cheap?
I just swapped my gray plastic wheel for a leather one, with metal flake gray buttons. Gonna toss all my leftover stock parts up on e-bay pretty soon.
Truck has about 5k on it, and I'm on my third steering wheel already.
whoo hoo.
Chris
If you go to the dealership they sell you a 'kit'. It's a wheel with the switches installed.
Costs on the close order of 165.00 plus local tax. They will probably have to order it.
There is no servo, etc, under the hood.
The wire harness is already in your wheel housing.
The 7 button radio control/cruise combo has a different harness. You might be able to get the dealer to add that, but it seems to vary.
The five button cruise-only is in there already.
Truly, you don't need to swap the wheel. 4 screws pulls out the dummy switches, then you can put in the cruise switches.
Nobody sells the cruise switches alone.
You still have to pull the wheel to swap them. Access problem, when the wheel is installed, the plastic surround between the wheel and the dash covers the screw holes.
The green cruise light is in the IP, you just can't see it unless it's lit. High to the right on the STX, low right on the FX4. No clue on the XLT, but you might be able to see it in the sunlight. It's round..
A good price for a cruise wheel is 50 bucks plus shipping, used but in like new shape.
Sometimes they're on E-bay. Be cautious and check out the vendor.
Note the color combinations;
The black wheel likes to come with the light gray switches.
The light gray wheel likes to come with the black switches.
The black leather usually has metalflake gray switches.
I started with a black plastic steering wheel, with black fake switches, black air bag, black surround (the thing with the two disk shapped covers you remove to get at the airbag bolts).
I put in a gray steering wheel, with the black switches, black airbag, black surround. Looked really sharp.
My wife wanted a leather wheel. Her hands bother her when driving long distances so I got a black leather wheel. I installed it with gray switches, black airbag, black surround. Looks good, not as jaunty as with the gray wheel, but nice.
Once you are programed for cruise, you can swap cruise contlrols till your bolts wear out, and the PCM remembers you have cruise.
The cruise on these trucks is the best I have ever used. I normally don't care much for cruise control, but on this truck it's so darn precise, I love it. I can drive all day and never vary two miles an hour.
Hope that helps,
Chris
Please read the Guidelines before posting. Edited by Admin
Thanks,
Aaron J. Wood
