4 way flashers
Old Feb 9, 2002 | 07:16 PM
86ford's Avatar
86ford
4 way flashers
my 4 ways are not working. right blinker and left work ok just not the 4 way. replaced the fuses, checked the bulbs in the back, they are ok. with the 4 way fuse out, i put my foot on the brake and the flashers lite but don't blink. Is this normal? Thanks for the help
Old Feb 9, 2002 | 08:19 PM
Mil1ion's Avatar
Mil1ion
4 way flashers
Are you sure you checked the right flasher?
there are TWO of them.
One for signals
One for 4-ways
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 9, 2002 | 08:28 PM
86ford's Avatar
86ford
4 way flashers
Dennis, I saw only 1, at the top left of where you plug the breakers in to. Is this the right one for the 4 way flashers. Where would the other one be? I did check all the breakers. Thanks for your help.
Old Feb 9, 2002 | 10:55 PM
Mil1ion's Avatar
Mil1ion
4 way flashers
[updated:LAST EDITED ON 10-Feb-02 AT 00:10 AM (EST)]Turn the 4-ways on and feel around for the flasher.
You should feel it click in your hand.
The other one you find should be for Turn signals.
One on the fuse box I think this is the turn signal flasher
One up /under the dash Left side> 4-ways
The book says :
The hazard flasher can be located in one of two places;it is either
located on the rear of the fuse panle behind the turn signal flasher or mounted on a bracket at the right end of the instrument panel.
Dennis
w/Explorer Pkge.
84 Volvo DL Wagon
Old Feb 13, 2002 | 12:23 PM
UPVFD30's Avatar
UPVFD30
4 way flashers
the flasher for the four way flasher is on the back of the fuse box. there is two bolts that hold the fuse box on. take them out and turn the fuse box over and you will see the other flasher.
1980 ford f-150
Old Feb 13, 2002 | 04:37 PM
Mil1ion's Avatar
Mil1ion
4 way flashers
Old Feb 13, 2002 | 08:46 PM
86ford's Avatar
86ford
4 way flashers
UPVFD30, thanks but the fuse for the 4 way flashers is not behind the fuse box I looked there. Mil1ion, I still cannot find that. I had the dash off trying to look down in there with no luck. I will try again this weekend. Thanks again
Old Feb 13, 2002 | 09:47 PM
Mil1ion's Avatar
Mil1ion
4 way flashers
I think he was repeating was I said in the previous post.
If it isn't under the dash in a recognizable spot then,
it is probably BEHIND the turn signal flasher in the back of the fuse box where you can't just see it ,you have to remove it to get at the flasher.
He said the *flasher* as I did,not fuse.
I know it's a DUMB spot to put it But, I guess them's the breaks.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
w/Explorer Pkge.
84 Volvo DL Wagon
pleckrone
Electrical Systems/Wiring
Jul 22, 2014 09:45 AM
abe
16
Oct 23, 2013 07:07 PM
John in Vegas
Oct 10, 2013 10:54 AM
kermmydog
Feb 26, 2013 06:36 PM
88fordf150
Sep 15, 2005 10:11 AM
