Sponsored by: Real Truck
alarm w/ remote start input needed
Old Feb 19, 2005 | 07:50 AM
  #31
AuRevoir's Avatar
AuRevoir
Compustar cost roughly $150.00 more than the Python. Still weighing out the pros and cons.
Old Feb 19, 2005 | 08:07 AM
  #32
jdadamsjr's Avatar
jdadamsjr
Originally Posted by dsweger
You can not tap into the "wait to start" light on the 2002 and newer Superduties. The "light" in the dash is turned on by a digital command on the data bus to the instrument cluster. The "light" is actually an LED curcuit operated at 5 volts (so I've been told). On the 6.0 motors, the Glowplug Control Module controls power to each of the glowplugs individually and is independent of the "wait to start" signal. The ECM looks at various parameters ( air temp, oil temp, etc.) to determine how long the "wait to start" indicator should be on and the GCM cycles the glowplugs as required for up to two minutes after the ignition is turned on.
I specifically bought a remote starter with the capabilities to monitor the "wait to start" light. Then after getting deep into the wiring diagrams, I find out it is not feasible on the 6.0 motors.
Nothing is simple anymore....!!!
Maybe it is...
just maybe you're forcing the hard route j/kiddin !
My remote start has been on for almost 2 years and it's always just been a timed event... doesn't monitor the wait to start and it's not important (TO ME anyway) that it does...
never timed it, but I think it waits 10 seconds then starts...
and has never NOT started
Just a thought...
have you EVER really watched the wait to start and seen it take more than 10 or 15 seconds ?
when u start the car remotely, does it REALLY matter if it takes 10 or so more seconds than you think it should to start ?
It's not like you're sitting there waiting on it
I LOVE the remote start and it will be on ANY future vehicles... and given the price of them now, I may start giving them out as Christmas presents !
Old Feb 19, 2005 | 08:20 AM
  #33
Bernie Lomax's Avatar
Bernie Lomax
I just got a Code Alarm CA610. Has shock sensors, starter kill, and remote start. Was $425 installed. So far so good. Only thing I dont like is that the "alarm" is the same one that every car out there has. Can I get a different sounding warning noise? I know some Code Alarms have that real powerful noise, not sure how to describe it. Can I change my alarm noise?
Old Feb 19, 2005 | 08:24 AM
  #34
dsweger's Avatar
dsweger
JD,
After, I realized I couldn't use the indicator, I did pay attention to the amount of time it stayed on and I never got past 7 or 8 seconds, (and that was at about 5 degrees). I programmed my remote starter for a 10 second delay and mine has never had an unsuccessful start either.
My unit also did a very good job of "syncing" itself to the tach signal. After the first two unsuccesful remote start attempts ( it cranked, but not long enough to start), I went through the "tach finder option" and it has never faltered since then.
All in all, I am quite happy with it. Cost me less than $100 and an afternoon under the dash.....
Don
Old Feb 19, 2005 | 10:03 AM
  #35
ROKNZRX's Avatar
ROKNZRX
CHeck out this Viper,
http://www.drdetailshop.com/V791XV.htm
three of my friends run it, I havn't been able to squeeze it into my budget yet, but as soon as I can it is what i am gettin'
Rich
Old Feb 19, 2005 | 11:39 AM
  #36
Black88GT's Avatar
Black88GT
Rich
Thats the one I want, and Ive heard its basicly the same as the Clifford model RS3.5 w/remote start. Best buy wants 580 to install it. Im waiting for another 10% off coupon
Old Feb 19, 2005 | 03:37 PM
  #37
duckhacker's Avatar
duckhacker
its 499 @ best buy here.
Old Feb 19, 2005 | 05:22 PM
  #38
Black88GT's Avatar
Black88GT
Yea, Its that here too, but the turbo timer would be a little extra to hook up and the proximity sensor is almost another 200
Old Feb 19, 2005 | 05:37 PM
  #39
jsikora's Avatar
jsikora
locks
Sorry but need to ask this...does anyone know where the VSM module is. I can't find it. I want to make sure It doesn't have one on the vehicle.
JEff
Old Feb 20, 2005 | 08:41 AM
  #40
sandpic's Avatar
sandpic
Hey Tazmanian Cowboy,
The guy is located in Toms River. His shop is called 1 stop car audio.
Old Feb 20, 2005 | 02:06 PM
  #41
tazmanian_cowboy's Avatar
tazmanian_cowboy
Thanks Sandpic. I'm going to check them out.
Taz
Old Feb 22, 2005 | 09:28 AM
  #42
sgthawkusmc's Avatar
sgthawkusmc
Yes. There is an optional add on for a bunch of different sounds. Check out your installation book or talk to an installer.
Old Feb 22, 2005 | 09:54 AM
  #43
Picnic's Avatar
Picnic
Thumbs up
jsicora,
I looked for quite a while on mine and finally found it over the tranny hump... behind the stereo, although, you cant get to it from the stereo hole when removed... to help me, I took the garbage hook plate off and could see it from there... then just reached up and around the gas pedal.
Last edited by Picnic; Feb 22, 2005 at 09:56 AM. Reason: mispell and adding more info
Old Feb 22, 2005 | 08:20 PM
  #44
93-331-29PSI's Avatar
93-331-29PSI
I have a Viper alarm/remote start with the little LED screen key fob. Can start it from nearly a mile away and the fob will chirp when the vehicle alarm is going off. Runs close to 500-600 installed depending on your dealer.
schlim66
2009 - 2014 F150
Nov 26, 2014 07:32 AM
thunderbolt427
Oct 3, 2010 12:46 PM
TIKT B8
Aug 31, 2010 10:20 AM
nut1605
2009 - 2014 F150
Mar 25, 2009 08:54 AM
jmusenkh
1997 - 2003 F150
Sep 21, 2006 01:47 PM
